Results 1 to 17 of 17
Thread: Cutting 16ga. Stainless
11-14-2008 #1
I built a custom console for my Chevelle, and I have been planning to top it with a sheet of stainless. I have a piece of thin MDF type stuff that is 1/8 inch thick mounted in place where the stainless goes. That is my template.
I bought a sheet of 16ga stainless, 12" x 48" and I want to cut it down to a 7"-8"ish wide by 37" piece. The side are completely straight, but they do taper in a bit. I would have used aluminum, but its too soft, and being a console, it would get all mared. The stainless should look good for a long time.
I tried to cut this stuff with an air cut off wheel, but its taking FOREVER. If I try to cut too much in one place at once, it yellows from the heat, so I have to make SEVERAL passes. My air compressor is a 10gal and I live in an apartment, so I don't want to piss my neighbors off by running it all day (or I don't want to burn it up). Plus, this does not give me the sharpest line, which is what I want.
My thought was I could take it to a shop (body shop, machine shop, steel supplier???) and maybe scribe my lines and have them cut it with a table sheer. From what Im reading though, thats right at the edge of what a sheer can cut, depending on how big the sheer is.
Maybe CNC/waterjet? but that would be expensive to have someone cut it that way for whats basically a trapizoid/rectangle. And I wouldnt even know who in Dallas could do that.
Any thoughts?
