    Results 1 to 17 of 17
      Kingsport, TN. 30 min. from Bristol and 90 min. from Pigeon Forge, TN.
      Best fitting 1 3/4 headers for 1st gen camaro?
      I got a DSE 600 box going in a 69' camaro with a small block. Stock sub with speed 3 kit and TKO 600 (mechanical clutch), stock steering column. I need a set of 1 3/4" full length headers to fit this. I was hoping to order the right set the first time around. Prefer ceramic coated too.
      Anyone here with this setup have any recommendations? I need to make sure we have plenty of steering box clearence.
      Thanks!
      Phoenix AZ
      Dougs, sorry don't have part number but i researched this and found everyone liked the fit. I bought mine coated from summit. they are still close to the box but no mods and they slid right in.
      Newbury Park, CA
      Lemons.
      Stahl.
      I've looked at the Dougs D368 1 3/4". The Hooker 2131 model I've seen used needed some massive massaging to clear the box.
      I know the Lemons or Stahl would both clear good but with coatings you looking at $1,600+. We are looking stay under $700.
      The D368 is around $550 or so.
      Anyone running these?
      Phoenix AZ
      that's the part number I used. I have a brand new set of Hookers I refused to put on. I really liked the Dougs and the way they fit. i could send some pics next week if you need.
      Pictures of box and pitman arm clearance would be great.
      Any other brand headers run with similar set ups?
      Niceville, Florida 32578
      FWIW, my 1.75" Hedman Hedders fit my '67 Firebird with no mods necessary and the best ground clearance I've ever had with headers on any car. While I had a TKO with mechanical linkage and PS I also have a Pontiac 455 engine. Still, I'd look at the Hedmans.
      All that is necessary for evil to succeed is that good men do nothing.
      Edmund Burke
      Phoenix AZ
      here are some pics of the dougs
      Feb 2007
      USA, TN
      More Pics of the Dougs D368 headers. There in a 71 Nova, but it is the same subframe. Stock type power steering.
      This is the tight spot on the left. I needed to shim the back control arm bolt so it didn't hit the header. Lots of room for the headers though
      The tight spot on the right. I had to move the idler arm about 1/2 inch. Plenty of access room for the starter, start wires and plugs.
      Thats the cinformation I was looking for guys. Thanks a bunch.
      Why did you have to move the idler and exactly how did you do it?
      Thanks again.
      Dougs D368s fit with no (zero) drama or massaging on either side in my 67 with the DSE 600 box and DSE steering coupling (didn't try the stock coupling). Engine has Edelbrock RPM straight plug heads with great spark plug clearance and Vintage Air mounted on the pass side with a March setup. I unbolted the steering box to simplify the install and it was by far the fastest and easiest header install I've ever done.
      Hooker 2131s in my 69 with the both the stock and DSE 600 box required massaging at the box, upper A arm (trim the square corner), pitman arm and steering coupling (DSE coupling only, stock no issue) on the driver side and starter (minor for both stock and aftermarket) on the pass side. Had to massage for spark plug clearance to use a socket on two tubes. Heads on the 69 are AFR 195 straight plug with Vintage Air mounted the pass side with a March setup.
      Both use Energy Suspension motor mounts (I think the number was 3-1114).
      FYI, with either combo I do spark plug changes using a ground down (thinner end) spark plug socket with either a long or short 3/4 gear wrench depending on the plug.
      Thats the type of feedback I was hoping to hear. I guess Doug's it is.
      JP, hope it works with your setup.
      What is simply amazing to me is that SBCs in Camaros have been around forever and yet some header manufacturers who have been in the b-nes for generations still don't have a clue that their market is based on fitment. I realize that the Hookers are designed to fit a specific combo that is in their application guide. Why Hooker doesn't have the common sense (or business sense) to look at feedback on their product that has identified the shortcomings of their standard designs for years and taken that info to develop some new designs that meet customer fitmets expectations is bizare. Hooker has the legacy name (that's why I bought my set), has the volume sales and yet the they won't listen. Perhaps (going back on my my original comment) Hooker does have a clue and the answer is that they make more money on the one-time sale without changes to the basic design than they would if they invested in the process and produced multiple products that fit.
      Bottom line, I wish I had read the "what Header fits" posts more closely years ago. I have no financial or other interest in any aftermaker supplier. My goal is to spend my limited resources (time and money) on things that work without drama. In my experience, Hookers did not fit on either my stock first gen or aftermaket setups, Dougs did.
      Thats what makes these forums invaluable. Feedback and recommendations from users not salesmen.
      Hooker sells the crap out of their headers. As long as thats still happening they have proven they aren't gonna change anything.
      SBC have a few different mounts but with Hooker's resources they could do better.
      Jan 2009
      Russellville,Arkansas
      Doug's Headers or Others that fit 67-69 Camero
      I just joined your group. I have a 55Nomad w/Rack (this is the problem)no one makes headers. I measured headers at shows finally came up & Purchased SuperComp Hookers for 67-69Camero 1-3/4 Tubes w/3" Collectors. But had to bent & flatted pass.tube to clear frame, Drivers side fell in but it hangs down a 1-1/2" lower than Pass. side. Allways Drags as car is low.
      I have tried to get measurements from Doug's and some suppliers. But no one wants to go to the trouble.
      Is there anyone who would go to this trouble? I sure would appreciate it. During week 800-643-9523 or cell 479-857-4621
      Oklahoma
      I Like they Dynatechs myself. Great workmanship and coating, inside and out.
      Aug 2006
      San Francisco, CA
      I'm running Doug's D368 also. My build has pics with the 327 motor mounts, which don't give as much clearance as the 350 mounts, which I'm switching to soon.
      Steven
      1968 Camaro: Project "TRACKDAY"
      Latest Track Weekend Video
      Build in Progress
