    Results 1 to 2 of 2
      Oct 2002
      Houston,TX
      MAP / Fuel Reg / By-Pass Valve (Line)
      Can I runn all three: MAP / Fuel Reg / By-Pass Valve off the same line or is it better to have adedicated line for one or the other?
      James J.
      Aug 2001
      Wilton, CA. (Sacramento)
      Quote Originally Posted by JamesJ
      map should have it's own line, shorter the better. The other two can share, assuming EFI (since it has a map sensor). With a blow through carb the fuel regulator line goes in the hat, the bypass would need a vacuum signal.
      Jody
