    Results 1 to 9 of 9
      Hackettstown, NJ
      Mechanical to electric speedo conversion
      As of now, my best option is Cable X. However, I would like to know if anybody can convert a stock mechanical speedo to an electric one or at least retain the stock gauge face and relative same numerical increments? I contacted classic instruments and tehy said it would run 800-1500 if they could do it. the car in question is a 78 t/a. any 70-81 firebird would be the same thouugh.
      Hackettstown, NJ
      I ordered Cable X after consulting a few gauge shops. this seems to be the best option.
      Nov 2004
      Colorado
      Just some advice from someone who uses a cable x: Don't use a metal jacketed speedo cable, it will sound like you have an egg-beater under the dash. Have a speedo shop shorten your factory cable.
      new york city
      Quote Originally Posted by Takid455
      Redline gauge works can convert your factory speedo to an electric version, and it will still look original.
      Walton, NY
      I researched this for quite a while when I put in my 6spd and have yet to come up with a good solution. I have read too many complaints with the Cable-X. So for now I figure it out my gear & rpm...
      Eastern Virginia
      I am in the process of doing the same thing, I found a late 80's Firebird speedo is electronic & pretty close to the Monte face. I took the electronic head off of the F body one, redesigned the Monte face so it still looks like it is for the Monte, but the angles between 0 & 120 match the Firebird one. Now I am trying to figure out how to get it on the Monte face. I have tried to find some way of getting it on a water release type decal, with no luck. I guess I am going to have it printed as a photograph, cut it out & glue it on the Monte face.
      Scot
      86 Monte SS
      Hackettstown, NJ
      great - I which I would have known these things before I order it. Murphy's Law in effect. anyhow, well see what it does. I'll keep the cable shortening thing in mind.
      as for the monte guage, that is not a bad though, however I will be needing one that goes slightly higher. 160-200 range. the previous owner got tired of burring the 100 mark so he installed a 50% transducer so for every one mph the car was going, the speedo read half of that. the gauge face plate was also revised to show the correct theretical speed.
      I'll give redline a call
      deleted
      Newbury Park, CA
      I talked to Shannon from Redline gauges yesterday at SEMA about this exact topic. I too want to keep the stock gauge face yet have an electronic movement to match the LS1 ECM output.
      For about $250 he will do the complete conversion and it will look just like factory. Takes about 3-4 days to do the swap. This is for a basic retrofit, no custom gauge facing.
      This is a no-brainer for me.
