Results 1 to 20 of 82
Thread: My 68 Firebird project
I was posting in the introduction area and did not realize there was a project update section. I am going to try to post some pictures in the vBGarage as well as some details on the build. i will update ant progress on this thread from now on
Steve
1968 Firebird. Owed and operated since 1981. 455 5 speed 4 link mini-tubed ect.....
03-09-2006 #2
03-09-2006 #3Gettin' there Steve...
Project "Freebird"
03-10-2006 #4I wanted to take some time and put a few details about my car up if any one is interested in info let me know. I love to talk about my car J I have had the car since 1981 between my sophomore and junior year of high school. It started life as a 350 2bbl 2 speed with open rear end. It was the lovely vedoro green with black interior. In 1990 I pulled the engine to freshen it and some how it turned into a 5 year full on restoration. A few years later as it was resting in my pole shed my then 5 and 6 year old nephews decided to see if they could hit the inside of the shed roof with rocks and rail road spikes. I will never forget walking into the shed and noticing marks on my car cover. I pulled it back to find several big dents and chips in my mirror like black paint job. I had it fixed but it never quite looked the same. I did not learn anything from the first time it decided to “freshen” the car up and 2 years ago I pulled off the front clip so I could redo some details on the subframe and engine and beef the engine up somewhat. One again it turned into a full on complete rebuild of the entire car. I am out of time for now but I will continue the saga later on. here is apic from the 1980s "glory days" I hope my son does not do he same things in his car that I did in this one
03-10-2006 #5Here she is in 2003 just before i toook her apart. What was I thinking!
03-10-2006 #6
03-12-2006 #7A few more pics
Misc shots of the project
03-12-2006 #8Here are some more details of the rebuild will add more later
Here is some more info
Engine
Block: 1971 455 .040 over bore. ARP main stud kit
Rods and crank factory pieces rods were reconditioned shot peened used ARP bolts
BOP urethane rear main seal
Rotating assembly was balanced
high volume oil pump
Heads
1971 #96 90cc chambers should be around 10.1 compression
Ported gasket matched heat cross over filled one piece SS valves ARP studs roller tipped rockers
Summit 2802 cam 224/234 duration .465/.488 lift 114 LSA (at .050)
Transmission
Tremec TKO 600
Centerforce dual friction clutch
Fuel System
750 Quadrajet carburetor custom built by Cliff and ľ” spacer
16 gal fuel cell in trunk with grounding strap.
Mallory comp 140 fuel pump with return style regulator
Mallory canister style fuel filter
˝” fuel and return lines
Fuel pump set up with relay to oil pressure switch. If oil pressure is lost pump shuts down.
Ram Air cold air induction
Ignition
MSD Billet Distributor
MSD 6AL box
MSD wires
MSD coil
Cooling
Rodney Red aluminum radiator with custom laser cut aluminum shroud
Custom built billet serpentine belt system also by Rodney Red
Lincoln Mark VII electric fan set up with thermostatic switch
Ram Air exhaust manifolds ceramic coated with X pipe and 2.5 inch dual exhaust
Rear End
9” ford rear end with 3:25 gears and an Auburn Gear posi unit
Disc brake conversion from TMC
Pinion mounted parking brake from TMC
Suspension
All bushings and body mounts are polyurethane
Edelbrock gas shocks
Subframe connectors and traction bars
03-12-2006 #9
