      Connecticut
      Does This Sound Right???
      i got a quote of 1268 for parts and labor to replace the fuel pump in my 2001 chevy camaro? i know the pump is in the tank and everything but does that sound like the right price???
      thank you
      Feb 2008
      Staten Island, New York
      depends ..yes if you include dropping the tank ...Pain in the A$$ .......
      but like many like myself i just cut a whole in the top of the floor board and pulled the pump out in less then an hour ... (you have to make up a plate to cover the hole when your done but if you work smart and have the right tools you can get this done in about 2 hours ... i will try to dig up my old pictures on how i did it on my car ...
      Jul 2008
      MI
      Most of the new GM cars use a whole module which contains the sender and the fuel pump. 2001 v8 cars use part number #25338871.
      List price is $624.18 for the parts.
      It kind of sucks considering you can get an aftermarket pump for a little over $100.00
      Feb 2008
      Quote Originally Posted by project hotrod
      ? you can pull apart the the plastic unit and install the aftermarket fuel pump...
      Jul 2008
      MI
      Quote Originally Posted by maldo
      Yep. Lots of people run the 255 LPH Walboro pumps.
      Oct 2007
      ridgefield ct
      IIRC on the camaro you have to pull the exhaust and the suspension to get to the tank. it is a lot worse than most cars so $1200 probably isn't bad. but cutting the trunk is a LOT easier, just be careful not to cut a wire or a fuel line!!
      i've seen alot of problems with the aftermarket pumps, i'd rather stick with GM.
      Jun 2006
      NW burbs IL
      Yes you can, I have done one. You can also cut an access panel in the rear hatch area and will not have to drop the exhaust or tank. I did this also.
      Here is a link to a trap door procedure for a LT-1 car, the LS1 door is wider and not as long.
      http://www.geocities.com/formulapower2/fuelpump.html
      Here is an Ls1, I cut it out and then just used RTV to glue an piece of sheetmetal over the hole. I had to remove it one and it was a piece of cake. Be sure if you replace the pump in the plastic oem bucket assy. cut a window for more fuel access to the pump. My car used to run out of fuel in a hard corner until I did that mod. Also VERY important is to use submersible fuel hose for the pump to outlet. I used what came in the new pump kit and they supplied regular efi hose. That is why I had to go back into the tank a year later. The correct hose is expensive, most autoparts stores do not carry it. I found one that did and it was $18 for 6".
      http://video.google.com/videoplay?do...14589991027401
      Here is a link to LS1tech where I pulled the links.
      http://www.ls1tech.com/forums/showth...nk+access+fuel
      Should only cost you around $150 at the most.
      Matt
      Connecticut
      wow very good to know. i can not swing 1200 doallrs for a car with 140,000 miles on it. i am very thankfull thought this is the only thing i have ever had to do to the car besides brakes and oil changes. oh yeah and i put in new plugs an wires but that is it.
