    Results 1 to 20 of 24
      Eastern Virginia
      Routing LT1 coolant/steam lines from back of heads?
      Originally I routed mine to a fitting on the radiator. It was a 3/4" hole or so that I screwed an adapter fitting into to allow me to connect the 3/16 or so hose to. My problem is I changed radiators & this one has plastic tanks & the fitting is now a molded plastic connection & I cannot use the adapter fitting. And I can't find one that goes between the two sizes. So what have you done? Drilled into the waterpump casting for a fitting or what?
      Scot
      86 Monte SS
      Mine is hooked into one of the heater hoses using a T-fitting from Napa.
      GeoffP
      68 Camaro - LS1/T-56
      Eastern Virginia
      Hmmm... I don't have any of the heater hoses hooked up. I guess I am going to have to have the pump drilled & tapped.
      Scot
      86 Monte SS
      Everett, WA
      Quote Originally Posted by Samckitt
      This is what I'm doing. Nice and clean installation. 1/4" NPT to 3/8" hose 90* fitting installed on the driver's side of the water pump. Then run a 3/8" hose to the steam line from the back of the heads (bypass the TB of course).
      The few, the proud, the crazy... the LT1 owners.
      Eastern Virginia
      Quote Originally Posted by 69LT1Nova
      That is exactly what I had decided too. I already was bypassing the TB by using a steam line from a 93 F'bird. It goes strait to the radiator. I too decided on the drivers side of the water pump, in the housing right at the fitting for the hose that goes back to the radiator. That means I have to take the f'ing water pump off.
      Scot
      86 Monte SS
      Everett, WA
      Well... that depends on how daring you are. You could always jam a rag in the water pump (to catch chips) and do the drill and tap with it still on the car. This was what I was planning on doing. Hope it works I just have to take it easy and drill a pilot hole first to keep the larger drill bit from walking.
      Everett, WA
      From Street & Performance:
      Eastern Virginia
      OK then, whoever does it first, post their luck, good or bad.
      Scot
      86 Monte SS
      Jacksonville, FL
      I also used the 90 degree fitting in the water pump and haven't had any problems in the 6 years it has been running. I used S&P for the reference.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Jul 2003
      Anaheim Hills, CA
      Mine goes into my water pump.. a much cleaner installation like that.
      1968 Track Rat Camaro:
      Eastern Virginia
      Quote Originally Posted by Steve1968LS2
      That looks like an "LS" series motor, a little different, but I think I am going to route it into the waterpump on an LT1 also.
      Scot
      86 Monte SS
      Everett, WA
      I was like "WTF kinda LT1 water pump is that? The steam lines are all funky."
      Good call! But daaaang that is one clean engine!
      England
      I've run mine down the right hand side between injectors and manifold to the front by the waterpump then connected into the heater hose as shown,this is a 94 vette LT1.
      Eastern Virginia
      I have pulled out the pressed in tube fittings in the pump, tapped them & plugged them with pipe plugs. I guess I could use one of those with an An-pipe fitting & route it to there. Anyone know which one on the pump is a return/inlet, not an out to the heater?
      Scot
      86 Monte SS
      Eastern Virginia
      Anyone see any reason why I couldn't use the fitting that the hand is on in the picture below:
      It would direct the water to the area right below the thermostat.
      Scot
      86 Monte SS
      Everett, WA
      Wouldn't that be on the wrong side of the pump? You'd be putting hot coolant/steam from the heads to the cold side of the pump? Time to find a coolant flow diagram...
      Everett, WA
      Nevermind... I found this by doing a Google search. Looks like you aren't the only one with this idea.
      Eastern Virginia
      Found these, I can't tell whether it is an outlet or an inlet connection.
      In the second picture, hose #9 is the one that connects to the steam line & then to the throttle body.
      Scot
      86 Monte SS
      Everett, WA
      Yep, heater outlet. From the previous post, apparently they changed the 93-94 configuration to the 95-up. Odd... this is different from the B-body LT1 that I have. Gotta love the consistancy at GM!!
      Eastern Virginia
      So the fitting I want to use is an outlet from the pump (high pressure) going to the heater? My motor is a 95 F body motor.
      Scot
      86 Monte SS
