    Results 1 to 10 of 10
      Knoxville,TN.
      very low rear brake line pressure.KORE3& Right stuff
      I have installed my Kore3 front brakes and Right stuff power booster,master cylinder and prop. valve. I am in the process of bleeding my brakes and have very little pressure when opening the rear bleeders.I went on to the front and they bled just fine.We tried pumping and bleeding 8-10 times and just can't seem to get very much fluid pressure to the rear.I am using a 1" bore master cyl. and the rear brakes are the factory drums.I suspect a bad prop valve but not sure.have any suggestions?
