Results 1 to 15 of 15
Thread: 160 degree T-stat?? Worth it??
- Aug 2007
- CT
- 799
Is a 160 degree thermostat worth the $60.00 from SLP..
Will it give any extra power or make the car run better?
2002 LS1 with CAM..
09-17-2008 #2
- Jul 2006
- Chesapeake, VA
- 679
No. These engines are designed to run much warmer than that and are more thermodynamically efficient at higher temps...short of inducing detonation or melting something, of course. Most of the time when people resort to very low temp thermostats on any engine it's a cheat to try to get a car to cool when cooling is marginal.
09-17-2008 #3
- Mar 2005
- Jackson Ms
- 1,220
my tuner said go 180 and Not 160.
Chris V
SOLD
09-17-2008 #4180 would be the best. Jaybee is correct. You want the engine to come up to temp quickly. Until that point stuff isn't sealing correctly and you are experiencing more wear until it does. The thermostat really shouldn't be kludged to fix what is a cooling issue.
09-17-2008 #5
- Aug 2007
- CT
- 799
What is stock?? 195??
Is there any HP gain??
09-17-2008 #6
- Aug 2004
- Dunwoody, GA
- 4,984
