    Results 1 to 1 of 1
      Portland, OR
      Advice for "bolt-in" DSE SF Connectors
      Just installed my DSE s/f connectors and wanted to get your thoughts on a bolt in mod. I welded a 1/8" top plate to the DSE brackets and drilled out the spot weld holes to accept 3/8” G8 thru bolts. I also added crush sleeves inside the s/f tubes and drilled a 3/8” hole thru the tops so I could bolt them to the top plates. I tacked the brackets to my s/f and the setup seems pretty stout, but I'm wondering if the holes will elongate over time? Would welding in some washers around the bolt holes help?
      Dave
      69 Camaro
      "Talk is cheap because supply exceeds demand."
