      Jul 2008
      Cedar Creek, tx
      Disc brake swap questons
      I have a 98 Trans Am I was going to take the engine out and part our the rest of the car. I started wondering and searching threads to find out how much of the brake system I could use on my 65 chevelle wagon?
      I thought I read somewhere that I could use the front spindles and brakes but I can find where I would have read that. I have found threads about using the rear brakes.
      Thanks in advance for your help guys!
      Oregon
      I believe BRP Hot Rods sells the adapter brackets that you're looking for to adapt your LS1 F-body calipers and rotors to your A-body spindle.
      The only thing you're going to be able to use the fourth generation front spindles on is a fourth gen F-body, but the LS1 spindles are worth something to the LT1 F-body crowd...they're much more conducive to big-brake kits since there are no integral cast caliper mounts.
      Tobin
      KORE3
      It's what I does.
      May 2002
      Northern California
      Don't forget the booster,master and fittings.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Chico, California Nor-Cal
      the rears will work, unless you have stagard shocks, then you need 2 lefts.
      Nov 2004
      Dallas Texas
      front brake brackets
      I sell front brake brackets that would allow the ls1 rotors and calipers to mount on your 65 - spindle and hub mods are needed along with adapting the late model bubble flare lines to the older inverted flare fittings - check out this link for more info: http://www.pozziracing.com/12_corvet...es_on_fgen.htm
      its lower on the page below the corvette conversion
      60$ shipped per set - good cleap upgrade
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
      Jul 2008
      Cedar Creek, tx
      Thanks guys!
      Zman the links not working. I sent you a pm
