    Results 1 to 7 of 7
      Long Beach, Ca
      To boost, or not to boost?
      That is the question. Well I am considering supercharging my Nova. But I have a couple questions first.
      With my current engine setup, what do you think is should/have to change to make it adequate for boost?
      Blue Printed and Balanced 388 w/ 10.25:1 Hyper pistons
      Comp Cam Extreme Energy Hyd. Cam
      .477"/480" Lift, 224*/230* @.050 268*/280* Adv. Dur., 110 L/C
      Comp. Cams Roller Tip 1.6 rocker arms
      Dart Iron Eagle Heads 200cc Intake Runners 2.02"/1.60 Valves
      Edelbrock RPM Airgap Intake Manifold
      Holley 750 CFM Carb Double Pump Mechanical Secondaries
      MSD Distributor and Ignition w/ 6000rpm Limitor
      Hooker Headers Competition Headers
      I know that my cam will bleed off some pressure, but is it too much? If not is my compression too high?
      If so should I consider one of the copper head gaskets? Or will that throw off my quench?
      What charger do you recommend?
      And any other info you can throw my way is greatly appreciated! Thanks, Jon.
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Fontana, CA
      Too much comp and not enough overlap.
      The hypers are good for up to about 5 psi max.
      What is your bottom end and what are your goals?
      Nick R.
      Sep 2001
      Accord, NY
      How much can an intercooler and water injection help with high compression?
      68 camaro - SOLD
      Farmington Hills, MI
      Quote Originally Posted by Rick Dorion
      Not enough to make 10.25/1 do-able.
      Intercooling is good for a couple PSI. I dont likt water injection. What if a fuse blows, or you run out of methanol. Hello Knock.
      JEFF SHORTT
      -IDEAL STEEL
      Fontana, CA
      If you have a remote adjustable wastegate the alky/meth/wateer systems are good as they are not constantly required, but that becomes an increasingly complex and expensive system. Intercooling is the best for a street car and constant use vehicle.
      Nick R.
      Sep 2001
      Accord, NY
      I really don't mean to hijack but I would like a low boost for my current 10.6:1 410 sbc. Just another 100 hp
      I was looking for a crutch to get me by for now. Maybe a drum of race gas to mix in.
      68 camaro - SOLD
      Give it the Giggle Juice (spray) if you are looking for another 100hp just to hold you over!
      JEFF SHORTT
      -IDEAL STEEL
