    Thread: FWD wheel Q
      McKinney, TX
      FWD wheel Q
      The wheels I have on my project Contour are 4x108mm lug. I was curious how close a set of 4 lug Mustang wheels (I don't recall the pattern). Also I believe mine are hub centric. What exactly does that mean and what would need to be done to fit non hub centric wheels to a hub centric car? Sorry if this is any bit confusing. Thanks.
      89 Mustang "Box Wine"
      Burleson, Texas
      Fox 4 lug Mustangs are 4x108. You'll need to take a measurement of the hub & the center bore of the wheel and get some hubcentric rings. They are just a plastic ring that takes up the gap between the wheel & hub, you may get a vibration if you don't run them. You should be able to get them from a local tire shop, or they are on ebay as well.
      While they may bolt up I don't know if the Mustang wheels will have enough backspacing for the Contour, they may stick out.
      Aaron
      1979 Trans Am
