      Apr 2008
      auxilary fuse box
      I have the need for more fuse connections for fans, fuel pump, windows etc. ect in my 65 Elky. My stock fuse box is maxed out but works fine. I don't want to replace what works, but I would like to move all the add ons to another box to insure I don't overload the stock unit since it was never designed to handle this much power throughput, and to provide additional connections.
      I was hoping for a modern add on fuse box kit (hopefully with instructions). Saying I am wiring challanged is an understatement.
      Any help is appreciated.
      Newbury Park, CA
      Check out Painless wiring. They have an 8-fuse single relay 30A setup that may work well for you . It's very easy to wire in.
      Dec 2002
      Lost Wages, Nevada
      I completely... second that recommendation.
      Here's the fuse panel I'm wiring into this 1966 Chevelle for a customer. It has provisions for up to 8 relays and 16 or so MAXI style fuses. It uses a buss bar to mate both sections for the fuses so one side of each is hot via BAT +12v, and I use a 4-gauge wire that runs to a master 150-amp re-setable circuit breaker. Every add-on device for this car goes through this relay/fuse bank. I labelled everything so it all is easy to read, wire and make changes. I'm using relays for the Nitrous 6 box, trans brake, line lock, nitrous/fuel solenoids, fan over-ride, purge valve, primary fuel pump and secondary fuel pump. I also us ethis to fuse all of my IGN switched +12v sources too. Very handy. Just giving you an idea. Oh, and the relays (they just snap onto a bracket made just for them!) are weatherproof type too so even better!
      [email protected]
      Jun 2008
      Waukesha Wi
      gmachinz
      What brand is that fuse box you are using? Do you sell it? IF so how much?
      I too am looking for an aux fuse box for my syclone and am very close to ordering up the painless but like that setup much better.
      David Van Hulst
      '91 GMC Syclone #892
      '92 GMC Sonoma GT #516 Daily
      '92 GMC Typhoon #0076 Dads
      http://community.webshots.com/user/syclone892
      Ah-I wish I could say this is my design but I always look to factory GM stuff before EVER going aftermarket or designing for myself-GM puts a lot into their parts for longevity and when it comes to electrical performance, I have a lot of cool, functional designs. That fuse panel I am building can be found on 98-00 Olds Aleros. Some are white while others come in black-same otherwise. Go to the GM parts department and ask them-you'll have to order several items to gather it all to make it work or you can get lucky and grab one from a late model junkyard. My work involves a lot of custom approaches to problems and it all varies from customer to customer, but this relay/fuse block will serve anybodys purpose imo.
      [email protected]
      Jun 2008
      Waukesha Wi
      Ah I see, that was a reason I really liked it, factory look
      I have access to wiring diagrams etc I think I may look into this, I kinda thought about it before but never really moved off my thinking
      Apr 2007
      Huntsville, Tx
      Check out this thread. This is slickest solution that I have seen https://www.pro-touring.com/forum/sh...ad.php?t=44994.
      Hope this helps.
      Sam
      69 Firebird convertible T/A pro-touring custom, Now LS1/T56 six speed, 3:42 Eaton posi, 18" Iforged wheels, 04 GTO interior.
      www.fquick.com/SamHatco
      Jack of all trades, master of none.
