      May 2008
      SoCaL-Pico Rivera
      4.8L/5.3L motor with LS intake
      I have a 01/02 4.8L/5.3L motor. I wouls like to run a LS intake as it looks just that much better. Is there one that can be just a bolt on? or who make a intake that I can use ?
      Aug 2008
      it is a bolt on, but you will have to modify the water pump outlet, if you're using truck accessories. if you're going to get one, might as well try to find an LS5 intake, because the flow better than the regular LS1 intake. however, the truck intake works very very well.
      May 2008
      SoCaL-Pico Rivera
      LS5?
      Also is their a diffrence in a auto motor and manual?
      Jul 2001
      Detroit, Michigan
      Quote Originally Posted by 1badchevelle
      LS5?
      He meant LS6.
      There was no difference in how the engine was built; auto vs. manual.
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
      May 2008
      SoCaL-Pico Rivera
      bump
      May 2008
      SoCaL-Pico Rivera
      Does anyone have any tips?
      Jan 2007
      Temecula, California
      easiest way is going to be by swapping out to corvette or f-body/gto accessory drive. it will give you the clearance you need to run the intake.
      The f-body accessories look bit cleaner since it keeps the alternator down low.
      Dunwoody, GA
      You'll have to get a new fuel rail too designed for the LS style intakes. Your truck fuel injectors will work fine. However, make sure the wiring harness you use comes with truck injector plugs as they are different than the car ones. If you're planning to build the engine to the point of needing bigger injectors, switch to the car injectors now because the aftermarket injectors use those plugs not the truck style.
      Trey
      ~ Jon Hammond
