    Results 1 to 15 of 15
      Eastern Virginia
      How to remove factory decal/stripes?
      How do I remove factory stripes from the Monte SS nose & rear bumper that are both some type of plastic/compostie, not steel?
      Scot
      86 Monte SS
      Jun 2008
      Oklahoma
      A heat gun to warm them up and fingernails or plastic razorblades/plastic spreader to get the sticker off them use wax and grease remover to get rid of the glue. A stipe remover wheel will work on plastics but you are taking a risk of burning through the paint if you get it too hot.
      Eastern Virginia
      Heat gun? Hmmm... A hair drier get hot enough?
      Scot
      86 Monte SS
      Lees Summit, Missouri
      I would say a hair dryer won't get hot enough, at the very least it won't do the job well for you. Go spend $15 on a heat gun at sears.
      Later - Craig
      [email protected]
      '70 Chevelle (in storage now, probably will never be back on its wheels again!)
      North Jersey
      I removed the factory stripes from my old '85 SS and my old '87 SS with a heat gun and a small plastic scraper. After that, I just used some 3M Adhesive Remover to get the leftover glue off, then compounded and waxed.
      I also used the heat gun to debadge my Cherokee. Works great!
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      Eastern Virginia
      Really, they are $15 at sears? I am heading there now then. Gotta go to town anyway.
      Scot
      86 Monte SS
      Jun 2008
      Carol Stream, IL
      Can also use some fishing line to help get under there to help lift it off the car once the heat has been applied
      Eastern Virginia
      Heat guns are awesome!
      Scot
      86 Monte SS
      Eastern Virginia
      I went to 3 different parts stores in town & no one had 3M adhesive remover. Gave up on it & went to Meijer, & guess what, they had it there. Strange.
      Scot
      86 Monte SS
      NW Burbs, IL
      I've had good results using this product on metal:
      http://www.autobarn.net/3m-07498.html
      The 3M stripe and sticker eraser works great!
      Mike
      www.musclecardeals.com
      Oswego il
      I use a piece of hardwood, oak or similar, cut very cleanly at an angle to scrape.
      the older the paint job expect some phantom marks where the paint has not faded evenly under the sticker, buffing the area usually helps.
      Quote Originally Posted by vintageracer
      Ditto, great stuff!
      Later - Craig
      [email protected]
      Quote Originally Posted by Samckitt
      Yes they are!
      Later - Craig
      [email protected]
      Aug 2008
      yes, yes it does.
