      Feb 2007
      MOSER 12bolt with ford style bearings ?
      The question is does the bearing sit flush with the rear end? I would think so but when i install the axle the bearing will not go all the way into the tube, its about 3/16 from being flush and thats what i need for the c6 zo6 brakes to clear the backing plate for the e-brake, this has been a mightmare from the start
      Brandon
      Aug 2003
      The bearing should stick out about a 1/8" and the backing plate needs to have a slight groove / relief around the edge for it. Tobin has the borrect plates for the conversion.
      May 2002
      Northern California
      I agree....We made a set of 1/8" thick AL spacers that fit around the bearing. Check to see if your axles are touching the gear shaft.
      fyi 7900FM ends are flush mount ends.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
