      Oct 2007
      Kore3 C5 kit installed
      Well, my C5 brakes are on my 65 Pontiac. I got the kit from Tobin at Kore3. I am using a 77 Chevy Malibu master cylinder. My pedal feel is pretty light. I am going to adjust the pedal rod out and rebleed the brakes again. I am thinking that that should help things out. I only took it around the block so I don't have much else to report. The Kore3 kit was a breeze to install.
      May 2007
      Las Vegas
      KORE3 makes some great stuff!
      Glad to hear you've got that baby rolling, even if it is just around the block.
      Curtis
      Quote Originally Posted by KCTurbo
      Mine felt a lttle soft too, until I got a heat cycle in it... I did the Kore Big Z06 kit(C6Z06)..
      Dec 2007
      Carlsbad, Ca
      great products and awesome customer service. i did the c6 z06 stuff for a 9".
      Tim
      Build Thread Link
      Feb 2006
      Columbus, GA
      What Prop valve?
      Hey guys, What prop valve are you running. I installed the KORE3 C5 kit front and back, too. I agree...the install is great! My problem is that my pedal feels like a rock! I'm running a 68-69 Vette 1" bore master with a stock (I believe) 70 Camaro prop valve. I do have a 77 Malibu Master to put in the car but havn't got around to setting up the lines and fittings for it yet. Thanks for your help and suggestions.
      1970 SS Camaro, 502 RamJet, TKO600 Tremec, 3.91 Moser 12 bolt/Detroit Tru-Trac, C5/Z06 Brakes.
      Dec 2007
      Carlsbad, Ca
      give tobin a call. you most likely need a smaller bore mc. that would move less fluid per inch of pedal travel, therefore giving you a softer pedal. but, im no expert, so call tobin.
      Tim
      Build Thread Link
