Results 81 to 100 of 451
Thread: TwinTorino
TwinTorino
Finally getting around to getting some real progress done on this project - so I figured it was time to start a thread. I have spent a lot of time on the forums getting info for my projects - thanks to everyone!
This project is slightly different than most.. in that myself and a friend are both building similar cars at the same time, hence the "twin" Torino name. It took a couple of years to find two cars, round up all the moderns parts for both the cars, build a chassis fixture, etc. To date, one car has 95% of the parts needed, and the other is 85% there. For additional info on the cars and our builds - you can visit our site at www.twintorino.com
The goal is to have something that could be driven daily and hit open track road course days on the weekends. We also did not want to have the fuel mileage of a big block Ford
. The target is to have the cars completed for the 2009 Power Tour.
The cars started life as 1968 Torino GT Fastbacks. Both were 289 cars with FMX auto transmissions backed by a Ford 8". They are not rare vehicles to start with, nor did they have desirable color combos or options, so they are perfect candidates. Both cars were bought on Ebay and are southern cars.. as we gave up early on the rusty northern cars.
We are building these cars on a pretty tight budget and are doing everything ourselves.. so it just tends to take a lot of time rather than money. We have been busy buying and sellings cars and parts to pay for most of the project to date. Keeping in the cost effective theme - most of the parts are used and came from Ebay, Craigslist, Kijiji and forums like this one.
The engines are 4.6L DOHC ones from a 2004 Mach 1 and the transmissions are T56 6-speed from a 2004 Cobra. We went with a Mach 1 as the engine is all aluminum, and are a lot cheaper than the Cobra supercharged motors. The supercharged motors use iron blocks. The rear ends are 2004 Cobra 8.8 (31 spline inner/outer) as part of the IRS assembly. Cooling comes from 2004 Cobra aluminum radiators (36mm core) and Mustang 2-speed cooling fans. Exhaust will use Bassani stainless steel headers, and a complete 2004 Cobra Bassani stainless steel system to start (modified to fit of course).
The front suspension is a modified 2004 Cobra McPherson strut setup. The rear suspension is a modified 2004 Cobra IRS. The steering rack comes from a 2004 Cobra. Front sway bar is a 35 mm Roush bar, and the rear is 26mm stock unit from the IRS. Koni DA's will be used at all 4 corners.
Front brakes are 2004 Cobra PBR front calipers with 13" Brembo rotors, and will have Carbotech AX6 street/track pads. Rear brakes are 11.65" disk from a 2004 Cobra. Brakes will be powered by a Cobra hydroboost unit. 2004 Mustang pedals are used under the dash.
Wheels for one car will be Ford FR500 18x9 front, and 18x10.5 rear. The other car will run Axis Hiro 18x9 front, and 19x10 rear. Tires are Michelin Pilot PS2 275's in the front, and 315 in the rear. Track tires are yet undecided, although they will be 18x9 and be 275's all round and road course slicks.
Seating will be modified 1969 Torino buckets for daily driving, and Sparco Torino's for track days (although they will likely stay in all the time). Interior will appear mostly stock looking. The gauges will be custom (using a Mustang gauge clsuter to start) with silkscreened faces to mimic the original ones. A/C and heating system will be based on a modified 2004 Mustang system.
Wiring will be modified 2004 Mach 1 harnesses. It is much cheaper that way in comparison to aftermarket setups. Also more complicated this way though
Cars will retain the Cobra ABS brakes, traction control, PATS theft system (with key in the dash), keyless entry, and basically any other major electrical function a 2004 Cobra would have. We are getting rid of things like air bags, power mirrors and lots of other things that are not needed.
That is all for now.. here are some pictures:
Day 1 for both cars:
Powertrain:
Suspension/Brakes/Steering
Front donor suspension structure:
Seats:
Wiring (ouch):
Wheels/Tires:
