      May 2008
      SoCaL-Pico Rivera
      67 10 bolt on a 71 chevelle
      Can I use a 67 chevelle 10 bolt on a 71 chevelle? what would be the down side? 12 bolt are high $$$ if you come across a good one. I can just build up the 67 10 bolt. THis is a daily driver and will be in back of a ls1 motor.
      Thanx
      New Jersey
      If its an 8.2 10 bolt, its not really worth putting any $$ and time into it. I'd look for an 8.5.
      Camaro Convertible Build Pics - http://s447.photobucket.com/albums/qq198/rob07002/
      www.musclerides.com
      Rob Stevens
      Dallas TX
      Find an 8.5 out of a 71/72 BOP car. It will bolt in and hold decent power or can be built up as strong as a 12bolt. The axle tubes to center housing will be a weak link under a lot of power. You will want them welded by someone with a jig that knows what they are doing to make sure its still straight.
      Nov 2004
      Dallas Texas
      10 bolt
      the 8.5" you want only came in '71 '72 Skylarks and Cutlass! pontiacs had their 8.2" -posi's are plentiful and gears too and they have bolt in axles so no worry about C-clips breaking and losing an axle these rears will run you into the 10's W/O breaking too.
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
      NW Burbs, IL
      That rear end is about 2" narrower? It also uses a different spring perch.
      http://www.chevelles.com/forums/show...rear+end+width
      Loganville, GA
      The rear end is narrower but the spring perch is the same, only 64-66 models had the different spring perch.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
