    Results 1 to 15 of 15
      Oct 2005
      Houston TX
      Can you cut your springs?
      I have a 70 Chevelle and I have a set of Edelbrock 1/12" lowering springs on it. I also have 20" wheels in the rear with 285/30/20 tires. I want to lower the car another 1". Can I cut a loop out of the springs? Will that have any negative effects?
      OC CA
      Sure, you can cut them. Use a big cut-off wheel, chop saw etc. Try to cut through them quickly as to not heat the spring too much.
      For a 1" drop you should start at 1/2 coil or less.
      Mark
      LS1- T56
      under construction
      "Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
      May 2007
      Las Vegas
      Don't go crazy and take to much. I've seen a few where they took a coil and all of a sudden it was to low. Might want to be cnservative and only take .25. Better to do it twice than buy another set of springs.
      Curtis
      Dec 2007
      Carlsbad, Ca
      you will increase your spring rate. in addition, you will worsen your already bad geometry of your c4l rear suspension.
      post up some pics, id like to see that tire size.
      Tim
      Build Thread Link
      May 2002
      Northern California
      I believe the rear Edel's are pig tail on both ends. So nope. Fronts yes.
      It was hard to determine if you had questioned with the front or rears?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Dec 2007
      Carlsbad, Ca
      my original plan was to run the 11" rear springs with only a pigtail on the bottom. there shouldnt be a need for a pigtail up top. the springs in my pics in the sig are the ones i speak of.
      Tim
      Build Thread Link
      Nov 2002
      state of confusion
      They need to be long enough so that they don't get loose at full droop as limited by the shocks or move around due to lots of clearance around the post. There is some question whether cutting off the upper pigtail will leave the top coil flat enough to fit in its chassis side seat properly. End coils can be flattened, but if you don't know what you're doing or aren't very careful it is also possible to end up with springs that will crack after a while in service and put you at a real risk of having the broken spring pieces fall out. Never mind how I know this.
      On the other hand, chassis seat spring posts could be made larger in diameter and longer, leaving only the "flatness" of the end coils as something to be dealt with (eccentric loading tends to make compression springs less stable).
      Norm
      Gone but not forgotten dep't:
      USA
      Are the springs New ???
      Drive it a while , and it will settle a little bit.
      You need to put about 500 to 1000 miles on a new set of springs before they settle.
      Jeff Tate
      U.S.A.
      a few thoughts...
      Your spring load can change quite a bit in the first 1000 miles or so depending on the kind of steel used, so if they're new i agree, don't cut yet. Your spring rate will NOT change because of removing a coil or half coil or whatever, but your spring load will...that is, your car will be lower.
      You can flatten the end pretty easily by heating it up with a torch about 1/3 of a coil from the end. Heat it red hot, then flip it over and press the hot coil into the ground with you body weight. Herb Adams has a description and some good pictures of this in the book Chassis Engineering on page 35.
      Good luck!
      paul
      Feb 2008
      Quote Originally Posted by Chevy
      a few thoughts...
      Your spring rate will NOT change because of removing a coil...
      paul
      I really hope you aren't suggesting that cutting coils won't affect the spring rate.
      New York, NY
      Chevy, you may be a bit confused:
      Cutting the spring will increase the rate.
      Also, springs may "break-in" and settle slightly lower than initial installation, but the rate does not change.
      straight from Hotchkis Tech Support......yes you can cut up to one full coil from their small block springs, without affecting the spring rate.
      Feb 2008
      Quote Originally Posted by protour73
      i think that is probably a misphrased sentance.
      maybe they meant without affecting the spring rate significantly.
      especially if the coils come with closed ends originally
      Mantorville, MN
      Doesn't surprise me Hotchkis would be way wrong on something so basic...
      Derek Kiefer,
      Mantorville, MN
      Nov 2002
      state of confusion
      They could be correct, but you'd have to know in some detail what their small-block spring actually looks like to call it either way. If the end coil being cut off is inactive (bottomed out against the next coil as-installed), it has little or no effect on the spring rate to begin with.
      Norm
