      Sep 2007
      Buford, GA
      LT1 Power Steering Woes
      I think I burned up my PS pump when running the track at the Year One Experience. Better yet, I KNOW I burned it up.
      One of the members on here PARKERRS suggested I get in touch with a company out of Texas called "Performance Steering Components." They offer a power steering pump for the LT1. See THIS LINK for the pump.
      I know that "Lee" does some sort of modification too.
      Anyone have any good advice? What pump have you guys used?
      Adam
      1985 S10 - LT1 + T56
      Eastern Virginia
      If you have just a normal air power steering cooler, I have read that these work better:
      http://cgi.ebay.com/ebaymotors/LS1-R...spagenameZWDVW
      It goes in the radiator hose & power steering fluid flows through a coil in it.
      I haven't got one yet, but it is on my list of things to do.
      Scot
      86 Monte SS
      Sep 2007
      Buford, GA
      Thanks!
      That's a good, cheap alternative to what I'm planning.
      But I've been advised to get a nice tranny cooler and use it as a PS cooler. I've deleted the A/C so I've got plenty of room in front of the radiator so I'll probably go this route.
      Adam
      Eastern Virginia
      You will have to have the tranny cooler getting a ton of air through to pull out heat like water will. What I don't know is the temperature of the water once it leaves the radiator going back to the engine. If it will be cool enough to pull a lot of the heat out.
      Scot
      86 Monte SS
      Sep 2007
      Buford, GA
      Why was I thinking that tranny coolers used water too? Hmmm...
      Adam
      Eastern Virginia
      Well if your radiator has the provisions for an automatic tranny cooler then use it. Cause the T56 doesn't use it.
      Scot
      86 Monte SS
      Sep 2007
      Buford, GA
      Anyone else?
      Adam
      Sep 2007
      Buford, GA
      Anyone else have a better idea for an LT1 PS pump??
      Anyone use "Turn One?"
      Adam
