      livermore ca
      *lt1 guys* opti question
      i took the opti vent line off that runs to the intake and hooked somthing else up there and never hooked it back up. when i was out driving the car today it backfired and poped and shut off. once i hooked the tube back to the intake vacum line it seemed to run fine? could that be the problem?
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
      England
      What yr is the opti ?
      Eastern Virginia
      That vent line removes some kind of little particles in the air that result from a spark between the rotor & the terminal where the plug wires connect. I guess if that doesn't happen it can misfire.
      Scot
      86 Monte SS
      livermore ca
      its a 95. the car was missfiring but once i hooked it back up seemed to run fine. ill have to drive the car around the block and see if i got it fixed. its find scary tho it almost died in the middle of a intersection.
      65ss chevelle
      63ss nova
      3:73
