      Oct 2007
      Millsboro, DE
      VA Gen II install questions
      I'm putting a GEN II system in my 68 camaro. I'm getting ready to hook up the heater hoses at the evaporator. My question is that there are what seem to be rubber plugs with a hole in the end on hose the tubes coming out of the evaporator do i leave these in and slide the hose on over or remove what looks like a plug?
      Bulldog
      England
      If you go to there web site they should have the instructions in a down load.
      charleston, SC
      Or you could send a message to Frank at Prodigy. He sells and installs them.
      Robert's 1969 Camaro - 2002 LS1/T56, 10pt cage, Global West Stage III front suspension, HTH truck arm rear suspension, Sprint Cup 9" full-floating rear end, Fikse Mach V 17" up front 18" in the back and still working on it...
