      England
      Retro Electro Headlights
      When fitting the motor on the headlight plate the hole that the motor goes through is smaller than the brass bush, do I drill the hole bigger or fit the washers after the motor is fitted.
      May 2007
      Las Vegas
      I don't recall if we did that when installing mine. Though if I and when I do this again I wont use Retro. Installed just a few months ago and they are giving me problems. Next time will be DSE.
      Curtis
      England
      What prolems have you been having with them.
      Jul 2007
      Belvidere, N.J.
      When installing mine I used a round file and filed out the hole until the bushing fit. From what I remember, it didn't take too much filing to get it to fit correctly.
      Mark
      Mark E.
      '68 RS/SS Camaro, 350 c.i./400 hp, Thumper Cam, Hurst shifter, Muncie M-21, Pypes H-pipe w/violator mufflers, 18" Rushforth Battery Wheels
      Jul 2007
      Belvidere, N.J.
      Quote Originally Posted by Spiffav8
      What problems are you having with your set-up? I installed mine about a year ago and they have been working great ever since.
      Mark E.
      May 2007
      Las Vegas
      The passenger side won't open and close. The motor is good...I think it's the internal relay. Hope I'm saying that right.
      Curtis
      England
      I have opened the hole and it runs alot better with less tightening of the jam nut.
