    Results 1 to 18 of 18
      Apr 2007
      Huntsville, Tx
      Well, like I said before I got the brakes off of an 02 trans am axle, so I started with a left and right bracket. I needed another left hand bracket because there is clearance issues with the shock on the passenger side. Driver side shock is on the rear of the axle and passenger side shock is on the front of the axle. A left and right caliper bracket mount the calipers to the front on 4th gen f-bodies, so I purchased another left hand bracket from a junk yard for $25.00. This placed the caliper on the rear of the axle on the passenger side when you mount it. If you don't have the brake adjustment barrell clip you can get them from the dealership. I think they are less than $10.00. The actual lever will work both ways.
      Sam
      69 Firebird convertible T/A pro-touring custom, Now LS1/T56 six speed, 3:42 Eaton posi, 18" Iforged wheels, 04 GTO interior.
      www.fquick.com/SamHatco
      Jack of all trades, master of none.
      Dublin, CA
      The clip is what I was referring too, thanks. I have the brakes installed, just have not done the cables yet. I had planned on running them from both directions using a Lokar cable, but this might be a better looking setup.
      Brent
      1971 Camaro, LT1, 4L60E
      Feb 2008
      Staten Island, New York
      very cool set up
