Thread: Hello
07-13-2008 #1
Hello
Hi, just came across this site from another forum. I building a 55 Chevy with C4 IRS, IFS, T56, LS6..... I could use some help/info on hydraulic clutch set ups. I have swapped out the brand new and leaking TOB for a Mcleod and still have problems. What forum should I be posting this in?? I've done a little snooping around here and will continue to look for info
07-13-2008 #2Welcome aboard!
Lot's of good info. here. Do a search in the manual trans forum, and you'll probably find your answer there. If not, ask away.Mark
LS1- T56
under construction
"Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
