      Aug 2006
      LS1 and S&P oil Pan
      69 Camaro, LS1/4L60E
      I'm installing new ARP rod bolts and my S&P notched oil pan. The directions tell me I need to take leave out the windage tray. Here's a few question I need help with. Keep in mind I'm a body man not a mechanic.
      do I leave out the windage tray and the trap in the bottom of the oil pan?
      Why can't I just notch the windage tray where the pick up tube mounts?
      How important is the windage tray?
      69 Camaro Rag Top
      "Will trade wife for parts"
      Felton, DE
      Some stroker LS1s dont even run a windage tray. I helps remove excess oil from the crank journals. It woudl affect performance at top end but minimally like a few hp. From what i have read and been told. I dont fully udnerstand it's function.
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
      Dunwoody, GA
      You've got its function correct, Shawn. Windage trays can also prevent the crank from whipping the oil into a foam. I would try to run one if possible but it won't kill the engine if you don't. Do make sure you space the oil pickup tube though if you remove the windage tray.
      Trey
      ~ Jon Hammond
