07-09-2008 #1
New to Pro-Touring
- Oct 2007
- central, KY
- 50
engine removal for DSE upper and lower control arms??
Just bought the new DSE speed kit 3, new p/s pump, hoses and complete front BAER track kit...
When talking to the techs at DSE, they said the motor had to be pulled so the upper control arms can be located / welded... WTF??? Any experience with the DSE products in question??? Did you guys pull the motor or can you get around that step??
- Mark
67' RS Camaro - 468/476hp, polished, show car
68' Camaro drag car-507/752hp,-13.1:1, only 241 miles
79' TransAm- 540/763hp, Dave Monday custom built chasis,pump gas-10.2:1, LSM,CFS,Callies,AFR
80' Z/28- all original, black w/ red stripes, 2nd owner, loaded, all paperwork - excellent driver
07-09-2008 #2That step is needed because you have to cut off the original stock upper control arm/shock mount, and then bolt on their bracket supplied to the subframe (where your engine mounts are or right around there). You then mark the part where the bracket is on your frame.
After removing the bracket you need to cut into the frame where the markings are after removing the bracket.
The bracket is key because it will locate where you need to weld up the new upper control arm mounts after bolting it up to the bracket.
For a picture to picture install...http://www.lateral-g.net/tech_articl...lover_install/
Hope this helps.
07-09-2008 #3
