Results 1 to 14 of 14
07-01-2008 #1
41565 Makes some progress....tubs fabed and back on the ground
Finally was able to get photos figured out thanks to 454Bug! I have all of the mount tabs welded in and the wheel tubs fabed up. They are clecko'd in, in the event I have to pull them during the quarter panel install.
Driver side tub
Passenger side tub
My assistant on the creeper grandpa made him!
Back on the rollers after months in the air on a frame dolly
Rear view, had to remove the trunk torsion springs to get the tubs in. I made a 3" wide support to weld the underside of the filler panel to the trunk hinge brace for support. It is as solid as a rock. I intend on using gas struts to hold the trunk lid open.
Firewall is going to be smoothed as well...quarters first!
