      6.0 in 69 camaro
      Guy's just run up on a great deal on a 6.0 iron block truck engine to go in my 69,I know this has probably been asked several times but where is the best place to get motor mounts and trans mounts for this,going to be using a 6spd,also if there is any more info on the swap out there that i could check out please let me know.
      Felton, DE
      carshopinc.com or t56kit.com has the ATS plates. More expensive but they look nicer imo. You will need
      Motor mount adapter plates - ATS (t56kit.com) $125
      SBC motor mounts - $50
      sbc frame mounts - $40
      a clutch master cylinder adapter plate - $65 ( i think)
      new 67-69 clutch brake pedal assembly - $70
      an adjustable clutch master cylinder and new slave cylinder - like $260 modified (i think)
      a t56 crossmember - maybe $250
      You can buy all of that from t56k it.com. Thats where i got all of my stuff.
      This is the forum that has all of the information you could ever need
      http://ls1tech.com/forums/forumdisplay.php?f=28
      1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
      1978 Datsun 2+2 - 6.0L LS1 swap in progress
      1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
      http://www.myspace.com/shawnmacananny
      Dunwoody, GA
      This forum has plenty of info too. At the top of this forum you'll find a sticky of known swap combos. You should be able to find one for you 69 there. If you also do a search here you'll find a lot of people in your same position and the answers to many of your questions. Just remember that you 6.0 is the same as any other LSx as far as mounting the engine and getting it to run in the car. Good luck.
      Trey
      ~ Jon Hammond
      Thanks for all the info guy's.THANKS!
      heres the style conversion kit i sell as well, there is alot of options on how to do this swap so you can pick the kit that best suits your build
      Good Luck!
      Phil
      www.BRPHotRods.com
      Phil,thanks for the reply will be giving you a call soon.THANKS AGAIN!
