    Results 1 to 12 of 12
      Indianapolis, IN
      Not sure what intake you are using, but with the stock LS style manifold I run the standard LS PCV system with a one way check valve between the PCV valve and the intake manifold to keep boost pressure from getting into the crank case.
      I am sure you can do the same with a carb manifold with a set up like John Parsons or with a remote PCV valve.
      Of course I would install one of my catch cans also to keep any vapors out of the intake
      Hope this helps.
      Mike Norris
      Mike Norris
