      West-central Ohio
      Lower ball joint ? Afco vs. Moog
      I am looking to lower my '86 442 in front after an engine swap. I would like about an inch or so. I considered drop spindles but thought if I could install the tall LBJs and eliminate some bump-steer, better yet. My problem is I am unsure which ball joint is correct. I've researched Afco, Howe and Moog and the base diameter for the tall ones from Afco and Moog have a smaller base dia. than the original for my car. Am I missing something? Part numbers would help alot.
      The Howe seems to be the best but are pricey for me. It's not likely that I ever track this car, I just need the front a little lower. It already has Eibach springs all around.
      Thanks in advance.
      Framedoctor a.k.a. David
      1986 Olds 442 grey/silver 350 TPI/200R4 , AFI wiring, SC+C stage 2+ front susp, boxed rear control arms,Eibach springs/ Edelbrock shocks, Coys 17x8f 17x9r, custom 2 1/2 exhaust w/side exit.
      North Jersey
      FWIW, I have the Howe ones in my car, and am very impressed with the construction. I don't track my car either, but I do drive it "spiritedly!"
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      West-central Ohio
      I got some LBJs, I got a pair of the Moogs locally from one of our suppliers to the bodyshop where I work. They are the K6117, I think they are for a 2WD truck? The threads on this look to be a larger dia. Am I supposed to drill the top of the taper to fit?
      West-central Ohio
      The silent replies to my question inspired me to try the search button again. I think I found all the answers to my questions on SC&C's FAQs page. It felt like it was written directly to me.
      I'll have that humble pie now please.
      Central CA USA
      How about a link to it?
      I've seen the Howe units, but not the AFCO.
      David
      West-central Ohio
      The Afcos are circle track parts available at Summit, Jegs, or any other circle track catalog. They've been discussed on here but no one had ever listed part #s. I had even searched Afco and Moog by part # and came up empty handed. I've enlisted the help of a racer local to me, he's going to help me out.
      Can anyone tell me if the Howe units are a direct replacement for my car, or would I still need to enlarge the taper on the bottom of the spindle?
      North Jersey
      The Howe pieces I got from SC&C were a direct bolt-on for my car, no mods to the taper of the spindle required.
      2006 Infiniti G35x
