      Just outside Ann Arbor, MI
      Looking for wire crimp reference
      Can anyone recommend a good wire crimper for heavy gauge wire? I am looking to crimp ends on 1/0 gauge cables and want to do a good job without spending a bunch of $. My intent is to crimp the ends on the cable at one end with them actually in the car after I cut them to the perfect length.
      Thanks!
      Dion
      67RSSS502
      the only people that crimp wire like that and that would have supplies availible to the public would be large welding suppliers,most everyone here,i am guessing,,,use compression fitting(car audio). i had them make a 50 ft. ground(2/0) for my welder.
      personally,i have done it one time,i had a s10 with 12-15s,,,it had 10 batteries,the connectors were going to cost a small fortune,,,so i order some crimps(1/0) from stinger(car audio supplier) at the shop i worked at,,,,i used a set of channel locks to press one of the sides over on the wire(my crimps were split),then i did the same on the other until it was tight,,then i soldered the wire and shrink wrapped the fitting...cheaper and better than just a crimp
      Mar 2003
      Boringville
      i use this anvil type thing, you stick the connector or end under an anvil that has a point on it. It holds it all together, while you put it on the floor and bang it with a hammer, crimps it like no other. They are like $25, try any electrical supply place like terminal supply.
      I would also solder / heat shrink when done.
      Use a propane torch...And some Silver content solder for the best connection.
      Jeff,
      1974 Formula 400
      1976 Trans Am SR71 Blackbird
      2000 WS6 Trans Am M6
      yody... like this one?
      yody... i think i know what you are talking about, but just wanted to make sure it is something like this
      http://www.usahardware.com/inet/shop...ing/770122.htm
      thanks!
      Dion
      67RSSS502
      Mar 2003
      Boringville
      thats it
      Laramie, WY
      I have used my trim hammer and anvil that I got from Eastwood. Works real well.
      Tim
      89 Lincoln Towncar pro touring project ( new info found for handling)
      95 Explorer XLT OFF-Roader
      95 Chevy Suburban LT 4X4
      07 Harley XL1200L Low 08 Harley XL1200N nightster
      Would you vote for someone who doesn't stand up for the flag?
