    Results 1 to 20 of 22
      Winnipeg, MB
      Suspension Combo - input wanted.
      Well I have finally settled on the upgrades and additions for my, Pro-Touring project, Buick suspension. I think I have found a setup that will drastically improve handling while still maintaining decent street manors. I would like any input from the forum collectively on this combination.
      Tubular rear control arms from UMI – polyeurathane bushings.
      Polyeurathane bushing kit for front suspension and steering.
      Addco sway bars – 1 3/8” rear and 1” front.
      Bilstein shocks.
      Factory rubber body bushings. This is one of those ride/streetability compromises.
      Suspension techniques 1” drop coil springs.
      Rear seat braces(helps tighten body for T-top cars)
      Front frame braces and connecting brace.(ties front frame together)
      Simmons racing wheels with 245/40/17 fronts and 285/40/17 rear.
      Next year will see the addition of Baer Brakes.
      Any and all constructive input will be greatly appreciated.
      Jason
      Jason
      Buick Motorsports aka No Mercy Motorsports.
      1985 Buick Regal, Pro-Touring inspired to start. Full on pro-touring as time and money permit.
      Laramie, WY
      Jason, seems like a good plan. They make alot of suspension stuff for the G-body.
      Tim
      89 Lincoln Towncar pro touring project ( new info found for handling)
      95 Explorer XLT OFF-Roader
      95 Chevy Suburban LT 4X4
      07 Harley XL1200L Low 08 Harley XL1200N nightster
      Would you vote for someone who doesn't stand up for the flag?
      Nov 2004
      LYNCHBURG,OHIO
      what size wheels
      Buick Motorsports, what size wheels are you running.I figure that they are 17" diameter but what width and back spacing.On my 79'bu project I was wanting to run the 285-40-18'son the rear on an 18x9.5"-18x10" with a 4" back space with a narrowed 9" rear axle.Not trying to steal the thread but your tire sizes interrested me.Thanks for any help you can give me.
      dennis68 Guest
      Any special reason you want to run the absolute worst arm possible on the rear? You would actually handle better on worn out stock arms. Poly is the worst thing thing....no wait. Delrin/Teflon is worst, poly is second to the worst thing you can but in C4L set-ups.
      North Jersey
      I've been playing with G-bodies for about 7 years. I'm no expert, but I've put enough street miles on them to have learned a few things.
      Quote Originally Posted by Buick Motorsports
      The lowers will be fine. I recommend Edelbrock adjustable uppers though, with the spherical bushing on the frame side. I have this setup on my '88 and like it a lot.
      Too stiff and squeaky! Stay with stock rubber, IMO.
      They might be OK, but a cheaper and better choice are the stock F-41 bars.
      Bilstein shocks.
      No complaints on either of those. I have them and really like them a lot!
      What's the rate on them? I have Eibachs in my '88 and am happy with them.
      Both are good additions, and you can also add bracing from the core support to the inner fenders.
      Sounds good. I have 245/45 17s on my '88 on all 4 corners. The ability to rotate tires is a plus.
      Good luck with your project!
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      Nov 2002
      state of confusion
      Not the best choice from a 'bind' / 'addition of unintended wheel rate' point of view, but do-able. FWIW, the poly can be modded to eliminate some of the bind.
      I've also found that poly up front tends to squeak more noticeably than at the rear.
      Either you have lots of dragstrip use in mind or you have those backward. The F41 bars for my '79 Malibu (which I bought new to order, not off the lot) are 32 mm (1 1/4") front and 22 mm (7/8") rear.
      Any idea what the rate for those ST front springs is? Actually, you can get Moogs in a variety of rates cheaper than just about anybody elses, though you may have to trim them for a particular ride height.
      Norm
      Gone but not forgotten dep't:
      I vote for Hotchkis upper arms. As for rear tire size, anything more than 5.25" backspacing and you're getting into the framerail. I run 285/40/17's (5.25 b/s) out back on my Monte and it rubbed a hair until I installed the Hotchkis rear susp. package which stiffened everything up! Keep with one manufacturer-I chose Hotchkis. I have a ton of experience with 78-88 G-bodies-I've torn down more than most people have built so I know what they need. Email me if you have Q's. [email protected]
      Winnipeg, MB
      Thanks all for your input. What is the general consensus on polygraphite bushings in lieu of the OEM rubber?
      796spdbu...I don't have all the specs at my office for the rim combo. I will IM you the information when I get home.
      f-41 sway bars... cheaper if bought direct from a dealer?
      Jason
      dennis68 Guest
      Poly is OK in the front but NEVER in the rear.
      Winnipeg, MB
      Quote Originally Posted by dennis68
      So you suggest nothing other than the stock rubber for the rear, dennis68?
      I need this input from everyone, it's greatly appreciated.... I want to finalize my combo, so that i can start ordering.
      Jason
      North Jersey
      Jason, the F41 bars would be cheapest if you can find someone selling them either on the Evil site or from someone local parting out a Monte Carlo SS, Olds 442, etc. The F41 suspension was also available on base-model cars as well; look for F41 on the SPID decal in the trunk.
      2006 Infiniti G35x
      Bklyn NY
      I would go with the GW delium bushing lca in the rear.This is absolutely the best for handling........
      Nov 2002
      state of confusion
      Quote Originally Posted by WOOSHH
      Umm, no.
      Don't confuse flatter cornering, a slightly stiffer ride, and more side-to-side head toss with better handling. Do a search on the term 'bind'; it's the dark side of using poly, delrin, or Del-A-Lum in rear control arms.
      Be careful about describing anything that has to do with suspension performance as being the 'absolute best'. Very few of these things are, and taken individually I can't offhand think of any.
      BTW, welcome to the site, and understand that the above is intended as education rather than flame.
      Norm
      Central CA USA
      I'd rather have solid frame to body mounts, don't tie the front body to frame solid unless the frame mounts are solid. I'd go with solid now, and if you have ride problems try polly or rubber if you have to. I just don't like the frame moving separately from the body.
      Use stock rubber bushings on the A arms if you want a better ride. Delrin A arm bushings don't make the ride a lot rougher but rubber A arm bushings are not so bad.
      dennis68 Guest
      I need this input from everyone, it's greatly appreciated.... I want to finalize my combo, so that I can start ordering.
      In the case studies that have been run as well as some real world results; running rod ends in the lower positions is an improvement over stock, but leave the upper alone.
      I would go with the GW delium bushing lca in the rear. This is absolutely the best for handling........
      Actually it's the absolute worst thing to put in the arms in this particular application (C4L that is). The GW bushings are actually referred to as Del-a-lum, just a correction. Do some searches in this forum for "bind", "poly", and maybe "C4L" or "converging 4 link" for some more reference material.
      This site is probably one of the most advanced technical sites as it applies to cars and handling (cc might have us beat but it does require a fairly advanced level of education to follow at times). Stick around and learn a thing or two.
      Harriman, Tennessee
      Here's what I was going to run on my 72 442. GW lowers (I think... the ones I want have spherical bearings on one end) and the Eldebrock uppers which also have spherical bearings on the frame end. If you don't run the arms with the spherical bearings, as the rear twists you get bind. Even the stock rubber causes a bind, but because of the more flexible nature of the rubber bushings, you get less bind then with a urethane or the GW Del-a-lum. If you have a solid bushing on both ends of the arms, the bind is awful and causes a very stiff ride with suspension that just wont work!
      Keep in mind that I am no expert, but with all I have read I think this is a very good way to go, having the spherical bearings on both the upper and lower arms.
      Shiny Side Up!
      Bill K
      '72 442 "Inamorata"
      Honolulu, Hawai'i
      Polygraphite fronts?
      What was the final decisions in regards to the front end? I'm interested in this setup...TIA
      Mar 2003
      Boringville
      i am pretty sure you can run bigger than a 245 on the front of that car, i think a 9.5 will work on the front with a 275, although i don't own one. also listen to dennis the menace and hey norm on the rear suspesion thing
      May 2002
      Northern California
      im about to crap poly. C4L =
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      dennis68 Guest
      Over and over again.
