    Results 1 to 11 of 11
      Jun 2008
      2nd Gen Camaro, backspacing?
      Anyone save me some trial and error time,
      what's "normal" backspacing for a 70-73 Camaro if
      I'm looking to go 18x8 front and 18x10 rear
      Indiana
      I just did 18X8 with 5.625 bs
      and 18X 10 with 5.750 bs and it worked good.
      St. Pete FL
      Wow, that is a lot for the front. Do you have a pic? I would like to see how it turned out. Here is 18x8 w/ 4.5 & 18x10 w/ 5.5.
      HELP!!!
      Aug 2006
      Rear : 5.75" BS
      Front: some people run 4.5, 4.75 or 5" BS. To be safe, some guys recommend 4.75" for the front.
      Check www.nastyz28.com, there is a sticky on wheel and tire fitment.
      I am running 17x11 with 5.75" BS, I had to beat the hell out the seat belt hump and roll the fenders.
      72 Camaro RS:SOLD
      68 Camaro:
      LS6 Engine,Tremec TKO 600,5 Speed
      Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors
      Feb 2007
      I have 18*8 front 4.5 b/s rear 18*9.5 5.5 b/s would prob reun 5.75 in the rear
      Oct 2007
      Quote Originally Posted by 72Z/28
      Rear : 5.75" BS
      Heres the link for what he's talking about...i just happend to have it pulled up...
      http://www.nastyz28.com/forum/showthread.php?t=103596
      Indiana
      https://www.pro-touring.com/forum/sh...ad.php?t=43315
      Mine are actually 18X8 with 5.25 backspacing and they worked fine but you can go more depending on how low it is going to be I wanted more bs but thats all american offered.
      so what is shown is 18X8 with 5.25 bs
      18X10 with 5.750 bs
      Mike King
      I ordered mine 18 X 8 4.75" & 19X10 5.75". 79 Z28.
      Jun 2008
      Say I got the car dropped 2"
      that means more or less backspacing?
      seems like 4.75 and 5.5 is "safe"
      I just don't want to order some high end wheels and have to use a spacer
      I want toorder correctly the FIRST time so....
      Apr 2008
      Toronto
      just wondering if 5" of bs is enough for 18x8's in the front? i have the car lowered about 3-4" so the tires will tuck a bit. i'm running wilwood dynalite 12.19's with oem spindles. i think the hubs push the wheel out about 1/4". anyone suggest any more than 5" without rubbing the sway bar on lock? please help! wheels are being built monday!
      Indiana
      I'd suggest 18X 8 with 5.625 bs
