Results 1 to 11 of 11
Can Anyone recommend a good Electrical Breakout Block?
Hi,
I moved my battery to the trunk and then sent a wire forward to the starter and one to the stereo. I wired off the starter to supply power to the original wiring harness (where the battery used to sit).
I added a MSD 6AL box and I am now adding electric fans. I am concerned about pulling even more amps through the single cable running to the starter.
Is it a problem to use the Starter Solenoid as the terminal block for everything else?
Since this may be a problem I am considering running a second cable forward from the battery to some kind of 'terminal block'/'Break out block' that I could then send power to the fans, MSD Box and the rest of the car.
Is this overkill?
Does anyone have any recommendations for a seal-able Terminal block/box? (This would offer a single point to break out the main harness power, fan power, MSD power, etc... from)
(I guess this means it is time to install the AAW harness that is sitting on the shelf
