Results 1 to 20 of 51
Thread: I've got this idea...
I don't think it's necessarily all that original, but I haven't found any one else doing it yet. It's all about how I think that I can squeeze more mileage out of the LS1 in my 67 (which is a work in progress by the way).
I base this on the following knowns:
1. Higher compression ratios give greater efficiency (some books I have indicate roughly 3% for every 1.0 increase in the compression ratio.)
2. Forced induction further increases the compression ratio. i.e. 10psi of boost would theoretically increase the compression ratio. My LS1 is 10.5. With 10 psi, I calculate 10/14.7 + 1= 1.68
1.68 * 10.5 = effective CR of 17.6.
3. Running a lean A/F ratio is economical, but increases the risk of detonation (plus the formation of additional NOx)
If I combined all three of these, I think we can all be certain that my engine would destroy itself from detonation. The introduction of water/methanol injection would be my solution to this problem. I figure that water/meth connected as a fail-safe to cool the charge would allow me to side-step the risk of detonation. If there is a problem with the water/meth system, the AF ratio mapping in the program would revert to something safer and the boost somehow restricted. I am also figuring that this would cool the charge enough to reduce the formation of the NOx.
Okay, now everybody please poke some holes in this plan. I would really appreciate the feedback.
67 Camaro, LS1, T-56, MP122 Magnacharger
Project on the road, but never complete...
