      Dec 2007
      Bakersfield,CA.
      '89 F150 Big brakes? Any kits available?
      Anybody know who deals in brake kits for off center stuff like an 89 F150 2wd? I am not opposed to changing lug patterns either. Just looking for a way to get some good brakes under this thing.
      Jun 2006
      Katy,TX
      Man I'd look for a wrecked Lightning , the ones I've seen have some massive brakes.
      Orangeville, Ontario
      Finally some interest, woohoo. We're a rare breed, my friend. Good luck.. let me know what you find out.
      :3gears:
      90' F150 - 302 V8, 5 Spd, 275s on all corners.
      Loganville, GA
      Supa cheapo method - F350 brakes, except for the whole 8-lug part. SRW would be better than DRW brakes.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Oregon
      Quote Originally Posted by Randy67
      I've seen several 8 to 5-lug conversions done for Early Bronco applications running one-ton running gear, but it involves welding in holes and remachining rotors.
      For a more bolt-on solution, I would think you could run adapters to make the pattern change and then select a higher-offset wheel to keep the track width the same by negating the thickness of the adapter.
      Tobin
      KORE3
      It's what I does.
      Feb 2003
      St. Louis, Missouri
