    Results 1 to 7 of 7
      Wayne Due C4 Front Suspension Question
      I have a Wayne Due C4 front clip in a '67 Camaro and it has two sizes (lengths) of spacers to mount the upper control arms to the frame. I've looked at pics on this site and others and now I'm totally confused on whether the long spacer goes in the front bolt or back bolt. Anyone know? I'm sure spacers/washers will need to be added but I need a starting point. Thanks.
      Oct 2005
      Middleton, Idaho
      Mine has the same size spacer front and rear. However, I haven't had it aligned yet, so that may change.
      Steve Spoor
      Middleton, Idaho
      69 Rally Sport w/T-56, Quadra-Link, Wayne Due C-4 Clip, 420 SB2.2
      67 Chevelle, Art Morrison Chassis, 416 LS3, Inglese 8-Stack Injection
      2014 Ext. Cab Silverado, Lowered.
      Jan 2026
      How’s it going guys I know this is an old post but figured it’s worth a shot. What’s everyone with Wayne due front and rear running for alignments specs?
      Quote Originally Posted by Mbaroza12 View Post
      I would just use David Pozzi’s alignment specs for the front.
      https://pozziracing.com/first_gen_suspension.htm
      Aug 2003
      Thick on the rear for more caster with less shims
      Sway bar
      Do you know what kind of sway bar you ran with this clip.
      Des Moines, IA
