Results 1 to 11 of 11
Thread: 700 rwhp Gen1 Camaro help
05-26-2008 #1
Goal 700 RWHP
Target 67 camaro.
Gen 1 way.
Dart block race ready 2000.00
forged rotating components 2500.00
Heads 1800.00
Valve train 700.00
Aftermarktet EFI 3000.00
Supercharger Avg 3500.00
total 13k to 14k
Or
LS2? Pull out ?? here is where I need help....
How much can I expect to pay for the LS2 with harbess ect.
SuperCharger 3500.00
Conversion needs E.g motor mounts ect 1000.00
Any help understanding the LS conversion cosest would be appreciated.
05-26-2008 #2I don't know ..... maybe just buy this http://www.lateral-g.net/forums/showthread.php4?t=15023
add super charger and should be close to your goal?Dave
68 Corvair coupe
65 Impala SS
64 Corvair Rampside
62 Corvair Greenbrier
Asst. daily drivers
http://www.sourceboards.com/
05-26-2008 #3If you can spend 14k on a motor just get a dart BBC block and bore and stroke it out 700 rwhp would be easy with 700+ cubes
05-30-2008 #4
- May 2008
- 27
Let me tell you this, I have used DART block before and if you are going to use all QUALITY forged internals (Lunati crank, rods, and JE forged pistons or alike) with some really nice heads (Brodix, Dart, World) and EFI, you can get very close to 700HP without a turbo or supercharger.
9.8 deck with 4.5 bore (540 C.I.) with quality parts like I said above I have seen make over 650HP at 10.0 compression on pump gas.
05-30-2008 #5Thants a Dart little M block I believe the Max on those is 434 CID or 454 CID. But when yuo start to go thier the cost really rizes fast particalluy in machine work in the block.
05-30-2008 #6If you are into some fab. work, do a turbo setup and shoot for 800+ instead, long as you have the Dart block and all that, what the heck. 9.0:1 SCR, hyd. roller, 13-17psi with water/alcohol injection on a 406 or 427 SBC and you will hit 800 pretty easy I think, 700 without even trying.
Get a Brazil made Master Power Turbo, assorted piping, blow off valve, wastegate, V-band clamps, silicone connectors and let her rip. Headers will be custom unless you do the reversed exhaust manifold trick (guys do twin turbos with those as well). Should get by much less than $3500. Will need some fab. skills to do.
The torque curve with turbos is in my opinion superior to blowers. Wish I had a turbo instead. maybe next winter. . . .68 Camaro, 406, T-56, Hydroboost, IROC box, SC&C Stage1+, Hotchkis front springs and bar, Speedway Engr. rear bar, Varishocks all 4's, Vintage WW V48's
48 Ford F-1 pickup, 355, 700R4
05-30-2008 #7
- May 2008
- 27
Sorry didnt realise you were going little m, why? Why dont you just go big block? bigger cubes, more power and the little m block is only a coupple hundred less that the big m
HOTRODF1 has a point to, if you do want to go little m for whatever reason. go with a 427 c.i. little m block, forged internals, 8.5 compression and run a Precision turbo pt101 with 10-12lbs of boost and I you can put down 700HP VERY VERY EASY on pump gas (I Have seen someone with that setup make 820 HP on pump gas) Also, That way if you ever get the urge, turn up the boost to 25-30psi, throw in some race gas, and be running over 1000HP.
05-30-2008 #8I am a small block guy just have always been.
I also love turbos and only really lookes @ two options the gale Banks kit and the nelson setup and they bot seeme too Rich $$$ for my blood.
If you have any links to any buids I can look @ that would be great.
05-30-2008 #9
- May 2008
- 27
Go to the turbomustangs.com forum (ITS NOT JUST MUSTANGS) they have all the info you could ever need about building a turbo small block and even threads on building your own headers and all that fun stuff.
05-30-2008 #10
- May 2008
- 27
If you shop around for the best price and build your own motor and own turbo setup you should be able to build a complete 427 turbo 800hp motor for less than 14K easily.
05-30-2008 #11
- Aug 2004
- Dunwoody, GA
- 4,984
