    Results 1 to 19 of 19
      Castro Valley, CA
      Vintage Air/Firewall Questions
      So my car left today for paint and I am having the firewall shaved smooth. I wont be buying my Vintage AC for a while and was wondering if the bracket needed to get welded to the firewall or how does it stick? I dont want to screw through the shaved firewall.
      Also should I mount the bulkhead now and does it need to be in any special area?
      John S.
      68 "Bloodline" Camaro in assembly...
      Speedtech Sub, Alston G-Billet/Fab 9 rear, Ridetech coil overs, Moser axles, Fesler 19's, Lots of Anvil parts,Twin tubo LS3/T56, Carbon fiber manifold, and the list goes on and on..........
      Country Flag: China
      If you do a search on the topic you will find most with smooth firewall are running lines through inner fender on passenger side. Some drill holes and some use the blower hole depending on how car was originally optioned. You may be filling the blower hole when you have the firewall smoothed. Some are using bulkheads (makes for a tight connection under dash) and others are running one-piece hoses with grommets on firewall. Frank at Prodigy used some aluminum grommets for Empty Nest and will hook you up if you buy the vintage air system from him. Everyone highly recommends Gen IV system over Gen II. Either way you go you will need to have to hoses custom made after you get everything laid out in the car. Hope this helps.
      Castro Valley, CA
      what about the bracket that holds the ac unit under the dash? how does that stay in?
      I just dont want to weld on the other side of a freshly painted firewall
      John S.
      Feb 2007
      The Declining Market
      John,
      I just finished the pre-install on my VA GenIV, which also happens to have had a DSE firewall fill plate installed. If memory serves me correct, the upper and center bolt hole for the stock non a/c heater case is where you'll need to weld a bolt. That's where the evap case bracket will mount to. We welded a thick flat washer to the bolt for some support, and then welded the washer to the original firewall. I can find a photo if you need it.
      Dan
      1969 Chevrolet Camaro
      /DSE/SDPC-LS7/T-56/FORGELINE/BAER/VAPORWORX/SPEARTECH
      /DAKOTA-DIGITAL/RECARO/MOMO
      /MSP-FAB/BLACKTECH/
      Aug 2003
      There is no firewall mounting required on a Gen IV. EmptyNest has about as smooth a firewall as you can get. Here is a picture of the hose routing meenaggie mentioned (thanks BTW).
      Feb 2007
      USA, TN
      Do you have pics of the Gen IV mounted inside the car and the brackets required?
      Aug 2003
      The kit comes with brackets. I will look for pictures
      Jacksonville, FL
      Gen IV pictures
      Here are some install pictures, let ma know if you need anymore specific ones.
      http://rides.webshots.com/album/560202775dZkBLK
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Feb 2007
      USA, TN
      that is a nice looking install. It sticks down from the dash quite a bit or is the pic deceiving. How much glove box is left?
      Jacksonville, FL
      The glove box that comes with the kit is about the same size as the original one. It is made of plastic instead of the the cardboard stuff. I have my PCM and efi fuse block in the glovebox area so I don't have anymore room to stick anything else.
      Chris
      Feb 2007
      USA, TN
      Thanks for the information. The VA systems look pretty good and it appears to be what most of the custom installers are using.
      California
      Quote Originally Posted by TnBlkC230WZ
      Yeah, that seriously looks like it hangs down a LOT.
      I don't really mind losing leg room since I'm the driver, not the passenger, lol. Still, I don't really want a big box hanging below the dash.
      Matt
      May 2008
      Mesquite Texas
      I happened to run across a pic of the first gen vintage air units I had in my other 68...
      Just for ref only. It does not come down quite as far, but it is real close. Maybe a variance in the different generations of units?
      Notice the fan is different too.
      Feb 2007
      USA, TN
      Is there still plenty of room for feet? My wife would probably use it for a foot rest.
      Houston, Tx
      I spoke with Frank today about exactly the same topic. He said to drill 4 1" holes into the firewall as pictured above and you are set!
      England
      On the early vw rabbits theres a small open glove box that perfectly covers the unit and the pass does not loose hardly any leg room. And alway fit the unit with the pass seat removed.
      Aug 2006
      Richland, WA
      Quote Originally Posted by avgasman
      John,
      I used elevator bolts and just tacked them in place. Works like a charm. Also Frank's solution using the blower hole for all the A/C and heater lines is a very clean installation.
      Apr 2007
      Huntsville, Tx
      Here is a good picture on how I mounted mine. I used weld studs that I picked up from Fastenal. They are designed to be welded to the surface.
      Here is picture with the dash mocked up. I don't think it hangs too low.
      Hope this helps.
      Sam
      69 Firebird convertible T/A pro-touring custom, Now LS1/T56 six speed, 3:42 Eaton posi, 18" Iforged wheels, 04 GTO interior.
      www.fquick.com/SamHatco
      Jack of all trades, master of none.
      Portland, OR
      I made brackets out of 1/8" steel straps and welded them to the bottom of the cowl - one side of the front bracket bolts to an existing brace under the dash. The unit doesn't budge at all. Mine is a CAA unit, but I'm sure the VA could be mounted similarly.
      Dave
      69 Camaro
      "Talk is cheap because supply exceeds demand."
