    Results 1 to 12 of 12
    Thread: ATVs
      Apr 2002
      North Central Texas
      ATVs
      I tried to diversify the business for a little bit just to test the market. Around my part of the country there is always someone who has had their ATV or ATV loading ramps stolen. A friend and I made a product that would help prevent the theives from taking your ATV or ramps.
      Two versions are available one for a pick up and the other for a trailer.
      http://www.modoinnovations.com/id19.html
      Larry, If this is not acceptable let me know.
      Shannon
      Modo Innovations
      940-391-9002
      St.Anne Il
      dude that pretty cool..i have known guys had them stolen also..now they just use a bid ass chain and padlock them to the truck tie downs..this seems much easier ..good luck with it..
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
      Apr 2002
      North Central Texas
      Thanks, we went out and measured all the trucks, foreign and domestic and all the ATVs to make sure we made a universal fit. The ATV-LOC is fully adjustable and will fit any combination of truck and ATV as long as the truck has a 2" reciever and the ATV has a ball mount.
      Shannon
      Modo Innovations
      940-391-9002
      Feb 2008
      Denver NC
      Its a good idea and would work well for most ATV'S some of the sport ATV's like my LTR450 Suzuki not so well... Rule number one is if someone wants something bad enough they'll take it
      Apr 2002
      North Central Texas
      That is true, if someone wants something bad enough even incasing it in concrete won't stop them. The sport ATVs are so different in the way the differentials are made it would be extremely difficult to make a fit all type of unit other than a strap around the axle.
      Shannon
      Modo Innovations
      940-391-9002
      May 2002
      Northern California
      thats a great idea cause its a real pain to get the front straps in when its loaded. Need something to secure 2 dirt bikes too. That even more of a pain to get done.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Apr 2002
      North Central Texas
      Once the initial set up is complete (takes about 5-10 mins) you can load and unload by simply loosing the slack eliminator bolt on the upright, pull the hitch pin, release the coupler mechanism and pull the whole upright assy up and away. Then lay your ramps in the bed of the truck or trailer and stab the upright assy into one of the holes on the ramps, lock it and forget about someone walking away with them. The old way is to park on top of the ramps, then when you are ready to load after riding get in the truck pull it forward off of the ramps then load. This way, unlock and remove the upright, set your ramps up load and reverse the unloading process and drive off. Works on the aluminum folding or steel folding ramps.
      Shannon
      Modo Innovations
      940-391-9002
      chester Md
      couldn't someone pull the pin on the bottom, slide the bar up and out and now you only have the reciver on the ball left.. You could take that off later..
      you may want to add a locking pin there.
      Mike
      69 Camaro
      awaiting its new ls1 this winter..
      Apr 2002
      North Central Texas
      That is where a keyed alike hitch and coupler lock set is needed. We provide a hitch pin, the keyed alike hitch/ coupler pins are plentiful and many different kinds so we decided to not include them with the ATV-LOC. This allows the customer if they already have one or to use a brand that they like to purchase them. I can provide a set for about $30 extra if the customer wants. I got mine a Northern Tool.
      The keyed alike lock set is listed in the "Key Features"
      Key features of the ATV-LOC
      • Made in the USA
      • All steel construction
      • MIG welded
      • Black powder coated for years of durability
      • 2 built in slack eliminators
      • Coupler fits the common 2" ball
      • All hardware is Grade 5 or better (included)
      • Hitch pin is included
      • Prevents theft of your ATV with the use of coupler and receiver pin locks (recommended)
      • Prevents theft of your loading ramps
      • Assembly and installation instructions included
      Shannon
      Modo Innovations
      940-391-9002
      chester Md
      Good deal shannon.. I refered this to my brother..
      northern tool for the keyed pins.. good deal.. i need some for the car trailer and the other stuff.
      Mike
      69 Camaro
      Athens, GA
      Your product is similar to this one:
      http://www.cabelas.com/cabelas/en/te...d=cat20155&rid=
      Apr 2002
      North Central Texas
      I have not seen this version. The older version rattled in the receiver (doesn't have a way to get rid of the slack)and I didn't personally care for being able to pull a trailer behind it due to safety issues(I may be the only one with the safety issues). But other than that this version looks well made. He has Cabella's as a dealer so it has to be pretty good.
      Shannon
      Modo Innovations
      940-391-9002
