    Results 1 to 13 of 13
      May 2007
      Houston, Tx
      Air Compressor Help: Getting Ready to Take the Plunge
      So I am getting ready to take the plunge and buy and air compressor and I have been looking around and I honestly do not know what I should get. This is what I am looking at because it come with tools and looks to be fairly priced. What is everybodies imput on it? And what suggestions would you make if not this one?
      http://www.lowes.com/lowes/lkn?actio...609&lpage=none
      thanks guys!
      Colin Russ
      Jan 2007
      CT
      I was just in the same senario. My thoughts who makes the lowes brand? I just bought this from home depot http://www.homedepot.com/webapp/wcs/...3+90010+524403
      It is relabled from campbell hausfeld. It has a higher SCMF rating and a larger capacity. it is a little more money but I thought it was a better bang for your buck. I am happy with its performance.
      Dallas TX
      Judging by the price its an oiless type. The noise will drive you to suicide.
      Look in Craigslist for a good used one that is large enough in CFM to run air tools. A new one that will get close to doing what you need starts about $800-1100.00 depending on the quality
      May 2007
      Houston, Tx
      Quote Originally Posted by nicks67camaro
      that looks good! im gonna go check it out friday
      does anybody know of a good combo kit also? if I end up getting them separately i am gonna need some...thanks
      Colin Russ
      Dec 2007
      SW of Chicago
      May 2007
      Houston, Tx
      not looking to spend quite that much first time out...but thanks!
      Colin Russ
      Dec 2007
      SW of Chicago
      If you don't want something with the typical "oiless compressor scream"... Perhaps...
      http://www.amazon.com/DEWALT-D55155-...0789299&sr=8-4
      Dallas TX
      Quote Originally Posted by Young Gun
      Is this for mechanic work or body work? If its for body work save your money and get what you need or you will turn around and be buying again because you didn't buy enough compressor the first time. Been there wasted my money on that.
      May 2007
      Houston, Tx
      Quote Originally Posted by gearheads78
      I want to be able to paint small things, not a whole car obviously, it will be more for the pnematic tools... I want to have a spray gun on there that I can paint with though...but not to the extent of a whole car...
      Colin Russ
      TuoCo, CA
      this is what I have. It's a great compressor. I won't be doing any body work so it's good enough for me. It keeps up with a die grinder....
      http://www.chpower.com/webapp/wcs/st...1_10646_10692_
      Steve
      Check it Out Here
      well if your gonna spray then youll be using da sanders and everything else go big spend the extra i had the lowes 60 gallon when i had a body shop and man it couldnt keep up with long da sanding it wasnt bad but you would have to stop and wait sometimes
      quincy compressor
      buy a quincy 5 horse 2 stage 1,000.00 to 1,200.00 what ever you buy it needs to be a 2 stage or you will not be able to run a body sander like a d/a . i have sold the quincy 5 hp to several small body shops it has a presure feed oil system, cast iron cylinders and block it will be the last one you will ever need to buy i have seen 1950 models in body shops covered with dirt still pumping away. SEE AIR COMPRESSORS DIRECT.COM
      Rockford Illinois
      I have noticed a lot of compressors for sale in the local newspaper for really cheap. If you are not short on space you could buy 2 compressors and team them up together when you need the extra cfm. We have 4 ganged up at work and mostly run on 1 all of the time but always have a backup. The same concept can work for anyone. From what I have seen you could have 10hp worth of compessors for about $300 to $400 dollars and anywhere from 15 gal to 75gal of storage.
