    Results 1 to 11 of 11
      Dec 2007
      New york metro
      Will I be miserable cutting metal?
      I am embarking on a big project, big because it is my first time fabricating, and because it is at my friends house and I need to get done in a reasonable timeframe.
      I will be doing a full airride install on my 2002 Lightning, and fabbing a 3-link with a watts in the rear.
      I have a bunch of 3/16" and 1/4" plate steel for brackets and tabs, and .250 wall dom for the links and c-nothces.
      Welding is covered with my recent purchase of a Miller 180 with spoolmate, but cutting is a different story.
      What I have so far is as follows.
      A coule of harbor freight 4 1/2" angle griders with a couple dozen cut off wheels, grinding wheels, and flap discs. Also a electric die grinder that seems pretty robust.
      A HF laser guided jigsaw and a bunch of various metal cutting blades for it.
      A sawzall, and a new craftsman belt/disc combo sander, as well as a fairly small craftsman drill press.
      Will I be ok with what I have or do I need to break down and spend my hydroboost money on a H/V convertible bandsaw?
      Thanks guys,
      Ian Schwartz
      Ian Schwartz
      2002 Lightning
      "Go with Ian to the bathroom.......because we're not at school, nobody goes anywhere by themselves."
      Apr 2004
      Cedar Rapids, IA
      I don't think you will be to bad off with what you have. Most of the tools you have are better for sheet metal work then 1/4 steel but can still be used.
      One of thoes metal chop saws may be better for what you are doing.
      NY
      You should do fine with what you have. A cutting torch, or plasma cutter would make the job quicker, but it isn't a necessity. Keep your hydroboost money for your hydroboost.
      The needs of the many outweigh the needs of the few.
      Dec 2007
      New york metro
      Good thing, I just ordered up the hydroboost from Frank @ Prodigy....
      Thanks guys,
      Ian
      Ian Schwartz
      2002 Lightning
      NY
      Depending on "where" in the metro NY area you are, mark out your cuts, and we can get together and cut them with my torch. You bring the beer!
      Rockford Illinois
      You have everything you need to do a nice job quickly. The only thing I didn't see listed is a good vise and clamping system. Some good hole saws can also help.
      Good choice to buy an electric die grinder, they save a lot of electricity over air.
      The sawsall will be your best tool most of the time if you really get good with it.
      New York, NY
      i just use the harbor freight angle grinders for all my 3/16" plate tabs and for cutting tube. When I had to cut tabs to fit my axle tubes, I just used a cheap small, drill press to drill out the line i wanted...never had much luck with a sawzall (maybe works for tube) or with a jigsaw (takes forever to cut out a shape from 3/16".
      Dec 2007
      New york metro
      Toxic, thanks for the offer I am in the bronx, but the work is being done upstate in wingdale, NY
      Jim, I do have a good benchvise and a 3.25" holesaw the size of my axle tubes.
      Jerome,
      Thanks for the small drill trick to perforate the cut lines, i'll give that a shot.
      Ian Schwartz
      2002 Lightning
      NY
      Quote Originally Posted by pitstain
      20 minutes away, across CR-21 (really nice twisties) .
      Dec 2007
      New york metro
      The bridge is out.....oh and if you come by with a plasma cutter I'll buy the beer and pizza.
      Ian Schwartz
      2002 Lightning
      Feb 2003
      St. Louis, Missouri
      I bagged and layed my 99 F-150 frame with considerably less cutting tools than that. You should be fine.
