      Castro Valley, CA
      Need brake booster. DSE good ?
      Im looking for a good modern looking brake booster for my car. It will have an LS1 swap and for now I have factory disc in the front and eventually will have disc in the rear.
      Anyone running the DSE booster? Or should I try and find a stock corvette one and modify it?
      My other dumb question is once I find a brake booster (say I use DSE) which proportion valve do I buy?
      John S.
      68 "Bloodline" Camaro in assembly...
      Speedtech Sub, Alston G-Billet/Fab 9 rear, Ridetech coil overs, Moser axles, Fesler 19's, Lots of Anvil parts,Twin tubo LS3/T56, Carbon fiber manifold, and the list goes on and on..........
      TuoCo, CA
      If you're sure you want power brakes consider the hydraboost.
      You'll need a distribution block (stock is fine) or similar and you'll likely want a proportioning valve (wilwood, summit, etc) in the line going to the rear brakes.
      Steve
      Check it Out Here
