      Bay Area
      Grand National 8.5 10 Bolt
      Can anyone tell me exactly what I'm pointing to in the 1st picture. I'm assuming its a vent for the gearoil when it gets hot but correct me if I'm wrong. Also in the 2nd picture I'm wondering why one side has a bolt and the other does not. Something must go there. Last can someone verify the numbers for me on the rearend, 3TP G 124 HD. When I checked them last I believe it had 3.42 gears. I haven't had the chance to crawl under my Malibu and compare with the 7.5 10 bolt so I thought I would try here first. THANKS.
      Jose (Joe)
      1963 Nova SS Convertible
      1978 Malibu LT1/4L60E
      1978 Malibu Stock
      2007 Harley Dyna SB
      Pittsburgh, PA
      Not real familiar with the GN stuff in particular but:
      #1 You are correct that is the vent for the center section.
      #2 I would assume that is where the "tee" at the axle side of the rear brake flex line mounts. The hardlines to the wheels then attach to the tee.
      #3 No idea..........
      Shane
      dayton, oh
      yes, that bolt is for the tee where the rubber line goes in and the hardlines tee off of.
      dave.t
      74 Javelin AMX - stocker
      Bay Area
      I should've just put 2 & 2 together and seen that the hard lines (brakes) connected right there.
      Jose (Joe)
      1978 Malibu Stock
      2007 Harley Dyna SB
      Columbus, OH
      Not too sure about decoding the rear but I believe most of the GN's and 442's came with 3:42's.
      Eastern Virginia
      GN's had 3.42's & Hurst Olds 442s had 3.73's.
      Scot
      86 Monte SS
