    Results 1 to 20 of 248
      May 2001
      Mesa, Az.
      We're plugging away on the Olds trying to finish up this mini-tub project so we can send the car out and have it blasted. Basically the frame portion of the project is done. It took me right at 20 hours to do the labor. I could probably shave about 5-6 hours off of that if I did it a second time. If you are thinking of doing this PM me and I can send you some "pointers" that aren't in the instructions. Also took a little longer because I re C-notched the car at the same time. Last night we started cutting out the drivers side wheel tub after removing the trunk side body mounts. We had to stop and remove some dynomat so I took the opportunity to mock up an 18x12 and a 315 tire just for some inspiration. Since we don't have the inner tub out all the way the tire doesn't quite go in like it will. But it was still nice to get an idea..
      Phillip
