      Oct 2007
      ridgefield ct
      would this work?
      i'm trying to find the easiest/cheapest way to upgrade the axle in my g-body. i know the old a-body rears can be used but the upper control arm mounts don't properly mount up. what about a 90's b-body? i know the caprice 8.5in rear used a 5x5 lug bolt pattern but i'll be changing axles anyway, so i'll fix that. but will the control arms, springs and shocks line up and work?
      Dallas TX
      Not going to work as far as mounts. Its also more than likely too wide to.
      Oct 2007
      ridgefield ct
      the width doesn't bother me as a need wheel spacers anyway, but since the mounts won't line up, i guess it's back to square one. thank for the info
      Palm Beach Gardens, FL
      You could swap a 12 bolt with these modified upper control arms. I'm not sure which 12 bolt however.
      North Jersey
      Those arms are to swap a '64-'72 A-body rear into a G-body. The '64 and '65 rears are about an inch narrower on each end, IIRC. My '88 SS came with a 12-bolt from a '72 Chevelle, which I promptly sold since it was overkill for my car. I believe the rims that were on the car had ~5" backspacing and fit pretty well.
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      Oct 2007
      ridgefield ct
      this was an attempt at a cheap replacement. if i go to a 12 bolt it'll almost certainly be a complete unit from someone like currie or moser. or building and modifying an 8.5in.
