Results 1 to 13 of 13
Thread: Front subframe
04-17-2008 #1
New to Pro-Touring
- Apr 2008
- Tracy CA
- 5
Front subframe
I am a total newbie here i have a 68 camaro and i have being reading pages after pages of talk about what front subframe is better. I am trying to research what is best for me and this is what i would like. I would like to use this car as a cruiser/partial racer. I have a father in law with a new vette who despises old camaros. I want to prove to him that they can compete with his vette. I already have the Alston G-bar rear end, just figuring out what to do up front.
I live by Sacramento next to Alstons shop which saves on shipping and i like their stuff and i also like ATS kit but i want racki and pinion. DSE and AME just cost too much.
What can i do to shut him up?!
04-17-2008 #2
- Jun 2006
- TX
- 177
Why do you want rack and pinion? If you don't have the $$ for a DSE or AME frame you could always go with a ATS box and some AFX spindles.
Kyle
04-17-2008 #3
Certainly the CA frame wouldl compliment the g-bar nicely, not to mention the simplicity of using the same vendor.
One option for you to look into is Speedtech's new sub. I also have the g-bar and just got the Speedtech frame and even though I haven't installed it in the car yet, the fabrication seems top notch and the package was fairly priced.
Give Frank over at Prodigy Customs a shout, he's a direct dealer with vast knowledge of all the subs mentioned.Camaro Convertible Build Pics - http://s447.photobucket.com/albums/qq198/rob07002/
www.musclerides.com
Rob Stevens
04-17-2008 #4
New to Pro-Touring
- Apr 2008
- Tracy CA
- 5
I just have never been a fan of pitman arms, drag links, and steering boxes. Overtime there are too many oppotunities for play in each component. Rack and pinion just seems to be a bit stronger.
04-17-2008 #5
New to Pro-Touring
- Apr 2008
- Tracy CA
- 5
Speedtech uses a rear steer rack and pinoin correct? I am using an LS2 wouldn't it be better to have a front steer rack?
04-17-2008 #6
- Jun 2006
- TX
- 177
yes they use the Unisteer rack which can be installed on a stock subframe. You would need a modified or aftermarket oil pan. I have been considering this as an option but i haven't figured out which headers would work best with the setup yet.
Kyle
04-18-2008 #7Yes, Speedtech uses a rear steer rack, but I don't see why that would be an issue with your ls2. They use Steeroids and if you give Blake a call at Speedtech, he'll be able to tell you which headers will fit.
www.musclerides.com
Rob Stevens
04-18-2008 #8
New to Pro-Touring
- Apr 2008
- Tracy CA
- 5
If i do end up going with the full subframe i will probablly go with chris alston just because i live so close and it will be easy to pick up and use them for tech help. I just want to make sure that whatever suspension i choose it is able to keep up with the new vette.
04-18-2008 #9
New to Pro-Touring
- Apr 2008
- Tracy CA
- 5
Has anyone on here used an Alston subframe? If so what is the widdest tires you can run up front? Size and backspacing please.
04-18-2008 #10
